When I start my 99 conv up I get a blast of a mildew smell. Car stays w/ A/C at full blast. I'm on the Texas Gulf coast - humidity at it's finest. Smell is pretty much gone after turning on the car.
Running your fan on high without the AC before turning your car off will help dry out the vents. Leaving less moisture to create funk for the next day.
The dealership used a ventilation cleaner spray... smelled more like a mechanical smell for about a weak but no more musty funk.
Also, check under the passenger floorboard. Remove the floor mat, lift up the board. See if there is any water in the compartment. If there is, get it all out. The A/C drain tub will plug up and water will backup in this compartment. There is a post telling how to snip the end of the drain hose to make the opening larger so this will not occur again. Good luck
