How hard is it?
Old Jul 12, 2005 | 06:05 PM
tjcvett's Avatar
tjcvett
Default How hard is it?
Want to change my tranny filter. Read the manual and it states that when adding fluid, you have to have the engine running and add additional fluid while all this is going on. Has anyone done this, and if so, how hard is it? thanks tc
Old Jul 12, 2005 | 08:05 PM
wolfmd's Avatar
wolfmd
Ttt
Old Jul 12, 2005 | 09:24 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Once you have everthing back together put as much trans fl in as you can . Get in and crackup the car(with your foot on the brakes) go from Park - 1 stoping at each gear then back to park leave the car running & add fl until it comes out the fill hole. put the plug back in. I think that is all, but someone will correct me if I'm wrong
Good luck
To How hard is it?
