Coolant level sensor
Old Jul 14, 2005 | 11:39 AM
VA CORVETTE 757's Avatar
VA CORVETTE 757
Default Coolant level sensor
Where is the coolant level sensor for the computer? Visually I can see the coolant level is fine but the computer says its low.
Old Jul 14, 2005 | 12:15 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes, it is in the radiator, if your coolant is full, then the sendor is bad. Just unplug it, it will stop the light.
It is located on the left side, little low. If I remeber correctly
Old Jul 14, 2005 | 03:08 PM
JoesC5's Avatar
JoesC5
I was getting the "low Coolant level" DIC warning. The dealer had to replace the coolant surge tank, so I'm assuming the sensor is located in the surge tank, as that corrected the problem.
Old Jul 14, 2005 | 04:51 PM
Der Flieger's Avatar
Der Flieger
Default Coolant low sensor
The sensor is located on the bottom of the coolant tank. There is a plug that you can see that connects to the sensor. Sometimes it gets corroded or broken. The sensor is an integral part of the tank.
Old Jul 14, 2005 | 05:07 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
I had the same problem- Replace the coolant tank. The sensor plugs into the bottem of it and there is a "float" inside the tank. the Float was stuck on mine. If you order a new tank it comes with a new sensor
To Coolant level sensor
