My poor C5...
Jul 18, 2005 | 05:00 PM
My poor C5...
Until i can get the correct gasket for my blackwing... i had to make a temporary substitution...
I took a cloth, and folded it up so it over lapped itself, and lined the inside of the filter port with it... then stuffed the MAF in it.
Has anyone done this before...? Im just hoping nothing is allowed to come through (ie. sand...).
red
Jul 18, 2005 | 05:05 PM
Nope, haven't done that mod before.
Jul 18, 2005 | 05:09 PM
Cruise-In VII Veteran
Haven't seen that done before.
Hope it works out for you.
Jul 18, 2005 | 05:10 PM
Jul 18, 2005 | 05:13 PM
I think I'll leave this one alone. You might try the Tech section.
Jul 18, 2005 | 05:15 PM
Quote:
good idea
Jul 18, 2005 | 07:27 PM
I would say that is your problem.....
Jul 18, 2005 | 08:11 PM
Sorry...but I cant resist
Jul 18, 2005 | 08:14 PM
Quote:
and its already been taken out! it had to go...
red
Jul 18, 2005 | 08:38 PM
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '06-'07
Put the stock box back in untill you get the correct part.
Corvette's do not work well with Mickey Mouse mods.
Jul 18, 2005 | 08:47 PM
I thought you used rags for lost gas caps?
How about going to Home Depot or Lowes and go to the plumbing dept find a rubber coupling. That should fix the problem and then lose the rag.
Jul 18, 2005 | 08:58 PM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Jul 18, 2005 | 09:01 PM
CI 4-5-6-7 Veteran
I have the matching oil filter.
Jul 18, 2005 | 09:02 PM
Quote:
pics??
Jul 18, 2005 | 09:04 PM
CI 4-5-6-7 Veteran
Quote:
Originally Posted by pooter99
pics??
Jul 18, 2005 | 09:14 PM
I bought a Haltech Stinger intake. My hood wouldn’t close properly with the larger air bridge that the Stinger came with, so I had to adapt the stock air bridge to the Stinger filter. I didn’t have a tight seal with the smooth coupler I adapted to the stock air bridge because they were both smooth rubber. I fixed the problem by wrapping some rough double-sided tape where the two surfaces went together. You can’t see a thing where I did this, and it made a nice tight seal. I don’t know if this applicable to your situation, but I thought I would offer it anyway.
Jul 18, 2005 | 09:22 PM
Jul 19, 2005 | 08:50 AM
Cruise-In V Veteran
St. Jude Donor '04
Jul 19, 2005 | 08:14 PM
You do know this will be on every car site making fun of you right? Jesus Christ a towel? Get real.
Jul 19, 2005 | 08:33 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
