Flush Mount Taillight Kit
Old Jul 20, 2005 | 11:19 AM
msnyder_1979's Avatar
msnyder_1979
Default Flush Mount Taillight Kit
Does anyone sell this other than LAPD?
Old Jul 20, 2005 | 11:25 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
I think 21st has them give John a call. prices pretty much the same everywhere. See sig for link to 21st.
Old Jul 20, 2005 | 11:32 AM
msnyder_1979
He's out, but recommended West Coast Corvettes. Thanks for the info.
Old Jul 20, 2005 | 11:46 AM
C5starman's Avatar
C5starman
CI 7-8 Veteran
I bought the necessary stuff (longer stainless steel screws, spacers, rubber seals) at Home Depot for next to nothing. There was a write up on this, but I can't find it. maybe some else still has it.
It's no problem to do.
Old Jul 20, 2005 | 11:47 AM
QuikZilver's Avatar
QuikZilver
I bought mine from WCC (West Coast Corvettes).
Old Jul 20, 2005 | 01:02 PM
msnyder_1979
Damn, WCC is out of stock too... I need to figure out what parts to buy @ Home Depot.
Old Jul 20, 2005 | 01:46 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
I don't remember where I copied this from but I saved it for future reference:
Flush Mounted Tail Lights
(6) 1" L X 1/2 W X .194" Hole Size Nylon Spacers
(6) 1/4" L X 1/2" W X .194 Hole Size Nylon Spacers
(8) #8 x 2" Zinc Pan Head Screws
(1) Frost King Rubber Foam Weatherseal 3/8" W X 5/16" Thick x 10' Long (Adheasive backed)(I got the black weather stripping)
Simply unscrew tail lights, clean, put weather stripping around the tail light (where the red casing meets the black casing of the light) insert new screws and spacers on back side, screw back into mounting hole.
-The two center lights get one 1" spacer on each screw.
-The outside lights get three 1/4" spacers on each of the outer most
screw
-The inner screw on the outside most lights get one 1" spacer.
-Fit so the weather stripping looks good and screw them back in!
1" spacers $4.77
1/4 Spacers $3.42
Weather stripping $3.98
Pan head screws $.98
Old Jul 20, 2005 | 01:54 PM
Alcee1's Avatar
Alcee1
Flush mount is easy. I have directions here somewhere let me look. Ok I can't find the directions on my work computer, but here is what I remember (hopefully someone else will chime in to confirm - it has been ove 1 year since I did it) .
I believe you need (you can get it a lowes):
8 - #8 (not sure if that is the right number) 2-inch long screws - make sure you get SS so they don't rust
8 - 1 inch acrylic spacers
1 - roll of 1/2 inch thick Marine Weather Stripping
Installation:
For the inner 2 lights. You remove the old screws and replace with the new screws and the spacers. You will see that the light now is out, there is a gap between the light housing ahd the tail lamp and the light wobbles. The weather stripping will take care of the gap and the light wobbling. You need to figure out where the light should go then run the weather stripping around the inside of the light housing so that the light will lay flush against it. It is hard to write it, but not hard to do. FYI - I think I I had to add more weather stripping to the bottom of the light housing to get a better flush fit.
The outer lights are a bit more difficult because I believe (if I have this right) the outer screw uses 3/4 inch spacer and the inner screw uses 1-1/4 inch spacer. What I did was cut the 1 inch spacer to 3/4 inch and used the left over 1/4 inch piece with the other spacer. Again you will need the weather stripping to stop the wobbling of the light and to get a better flush mount. The weather stripping has adhesive on one side so it is easy to work with and if you make a mistake just take it out and start over.
Old Jul 20, 2005 | 02:00 PM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Spent about $9 and it was really easy to do.
Old Jul 20, 2005 | 02:55 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Several vendors carry them, but I got mine from LAPD.
Old Jul 20, 2005 | 05:26 PM
powderski13's Avatar
powderski13
About $9 in parts from Lowes. Easy mod that looks great. I added a plug & play sequential tail light module from Web Electric
Old Jul 20, 2005 | 07:28 PM
Cscokd's Avatar
Cscokd
let's see some pics of how they turned out
John
Old Jul 20, 2005 | 07:34 PM
Jetspeedz's Avatar
Jetspeedz
John
Old Jul 20, 2005 | 07:52 PM
jrose7004's Avatar
jrose7004
Some great instuctions folks!
Old Jul 20, 2005 | 10:13 PM
msnyder_1979
I'll post pics tomorrow night, after I wash the car. I just finished the mod.
Old Jul 20, 2005 | 10:31 PM
rcs128's Avatar
rcs128
I used the exact instuctions posted by Ad2Vet. Super easy and only cost about $8 for the parts.
Old Sep 29, 2005 | 09:39 AM
jawzforlife's Avatar
jawzforlife
hay guys, I'm going to be doing this my self tomorrow. But what are the nylon spaces? Are they just a nylon hose/tub cut to lenth. Or do I just go to home depot and ask for the exact size sparce and the guy will give me what I need?
To Flush Mount Taillight Kit
Old Sep 29, 2005 | 10:17 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
It sounded like a simple and cost effective alternative.
Old Sep 29, 2005 | 01:21 PM
jawzforlife
I just got back from home depot with all my parts, total was under $10
Thanks to the guys above who posted supplies and directions
Old Sep 29, 2005 | 03:22 PM
ZaydeZ06's Avatar
ZaydeZ06
You'll love it
