Tire wear issue!
Old Jul 21, 2005 | 01:50 PM
1vette98's Avatar
1vette98
Default Tire wear issue!
It seems that my right rear tire is wearing significantly faster than the left. I don't drive it really hard on acceleration, to avoid spinning the tires. Is there possibly an alignment problem that would cause this? I understand that vettes are subject to needing 4 wheel alignment, but I don't know if that could be the cause. Just curious if anyone else had a similar problem. Any ideas woud be appreciated.
Old Jul 21, 2005 | 02:24 PM
ls1vette97's Avatar
ls1vette97
Check the tire pressure, I set mine to around 30 psi cold....
Old Jul 21, 2005 | 02:29 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
First thing to check.
Old Jul 21, 2005 | 02:36 PM
1vette98's Avatar
1vette98
I keep the pressure at 33 cold, both sides. Don't think that is the problem. Fronts set at 33 also and they ae wearing the same on both sides. Thanks for the idea.
Old Jul 21, 2005 | 02:45 PM
Kanon's Avatar
Kanon
Mine did the same thing, but I don't know enough about how the previous owner cared for the tires to make an educated guess as to why. I just know the right rear was bald before the left rear.
I got an alignment and I'm checking my new tires with a tread guage to see if they're going to do the same thing...
Old Jul 21, 2005 | 03:06 PM
jrose7004's Avatar
jrose7004
Is it wearing on the inside or even or what?
Old Jul 21, 2005 | 03:15 PM
1vette98's Avatar
1vette98
It's wearing evenly, all the way across. I haven't measured the tread depth, but it is markedly different left tire to right.
To Tire wear issue!
