Fob ???
Old Jul 22, 2005 | 01:26 PM
jim_gard's Avatar
jim_gard
Default Fob ???
I have a FOB that is not responding. The other one is fine. I reset by holding the two buttons with no indication (beep) from the car to indicate that it sees the FOB.
Do I need a battery? If so, does anyone know what kind?
Thanks in advance.
Jim
Old Jul 22, 2005 | 02:12 PM
EDJ's Avatar
EDJ
On a 2000 the battery for the key fob is a 3 volt CR2450. You can find them at most drug stores. You may also have to retrain the fob thru the DIC. Both of mine have quit working so I looking for replacements. Good Luck, Eric
Old Jul 22, 2005 | 02:33 PM
jim_gard's Avatar
jim_gard
Default Thanks
Thanks. My car is a '98, so I'm wondering if the battery is the same.
How do I use my DIC to reset my FOB?
Old Jul 22, 2005 | 02:47 PM
jrose7004's Avatar
jrose7004
I'll bet you need a battery!
Old Jul 22, 2005 | 05:26 PM
The battery should be the same, I believe. The owners manual may have the battery type indicated in it. I would say that this is your problem with the fob.
Old Jul 22, 2005 | 07:34 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I just replaced the batteries in both fobs & did the relearn. Everything seems to be fine.
Old Jul 22, 2005 | 07:38 PM
C5 4 ME's Avatar
C5 4 ME
I have a '98' and the battery is the same.
Old Jul 23, 2005 | 09:06 AM
ebubman's Avatar
ebubman
we have a 2000 & have replaced both batteries & retrained. worked ok. good luck. bub
Old Jul 23, 2005 | 09:12 AM
EDJ's Avatar
EDJ
If you don't have a owners manual PM me and I can photo copy the instructions and send them to you. I imagine there the same as a 2000. Eric
To Fob ???
