Help! Self-locking car!
Old Jul 23, 2005 | 11:03 AM
lunatic's Avatar
lunatic
Default Help! Self-locking car!
My 98 Vert. locks when I walk bye. Just changed batteries in key FOB and it started. Switch for passive is in off. pos. I re-learned the FOB's after batt. replacemnt. ANY SUGGESTIONS.....
Lunatic
Old Jul 23, 2005 | 11:50 AM
rockrz's Avatar
rockrz
Usually means either a dud battery or your fob had more problems than just the battery and you need to replace it. I'm betting on a bad fob. Look for one on Ebay.
Jerry
Old Jul 23, 2005 | 11:58 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Yep, bad FOB.
Old Jul 23, 2005 | 12:06 PM
jessejay356's Avatar
jessejay356
Lunatic
I had something simular happen. Turns out the passive switch was still on. I'd take the fob apart again and look at the rubber piece with the buttons and make sure they are seated properly. I think that was causing the passive switch to be on when it should not have been.
Old Jul 23, 2005 | 01:47 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Make sure the "PASSIVE" switch is off - take a small screwdriver or something like that and really slide the switch all the way to the left as far as it will go.
I have a '98 also - and I once made the mistake....."Hey, how does this work?" Never again!
Old Jul 23, 2005 | 04:12 PM
droopwv's Avatar
droopwv
Mine did this after I recently changed the battery and I had to reprogram the fob twice and it hasn't done it since.
Old Jul 23, 2005 | 05:27 PM
lunatic's Avatar
lunatic
Lunatic
Sorry guy's didn't tell you this is wile its in my garage when I walk by WITHOUT the keys. At first I thought it was the keys as I leave them on the floor when its in my garage.
Lunatic
Old Jul 24, 2005 | 12:31 PM
1998 GTR's Avatar
1998 GTR
It's probably both locking and unlocking every few minutes. My '98 does the same thing if I leave the key fob too close to the car, like even in my kitchen. What it's doing is sensing the fob and thinking you're appraoching the car and automatically unlocking it. It will cycle through this every few minutes, continually locking and unlocking the car. You just happen to be walking by and hear it happen.
I once left the key in the kitchen (immediately above the garage) while out of town for an extended period. When I got home the car battery was dead from repeatedly activating the locking mechanism. I now keep the keys at the other end fo the house, out of range of the car's sensor.
I think there's a way to deactivate the auto-unlock from the DIC if it's really a problem. I think it's in the OPTIONS menu.
Old Jul 24, 2005 | 12:47 PM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Lunatic
OMG the car has you programmed
Thats a new one
Old Jul 24, 2005 | 01:04 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
Thats a new one
Old Jul 24, 2005 | 01:09 PM
lpabsolute's Avatar
lpabsolute
Originally Posted by ben dover
Yep, bad FOB.
Old Jul 24, 2005 | 01:30 PM
gordonb50's Avatar
gordonb50
I've been trying to disable the passive option for over a year. Only thing that finally worked for me discovered totally by accident - kept one of my FOB's out of range for over a week. Then, when I used it (or tried to), it wouldn't work. I re-sync'ed (held lock/unlock buttons) until the horn honked, and it finally worked without the passive option. Then I traded FOB's and used the same procedure for the secondary.
Sliding the switch on or off never would work for me and I couldn't find anything under options on the DIC that would allow me to turn off this function.
To Help! Self-locking car!
