Falken tires
With that said though.....my next set will probably be Kumo's in Z06 sizes.
but come on guys stop comparing a worn out tire to a brand new one and saying its x amount quieter and its this much better
think about it
every tire post i read pitches pretty much every tire better than the runflat and thats jut not the truth
Greetings to you. Here is a little information regarding Falken Tires that may be of interest to you: Falken Tire has been in production and available to the consumer public for nearly twenty years. Falken Tires is the specialty performance division of the world famous Sumitomo Rubber Tire company. Sumitomo is one of the oldest leading tire manufacturers having originated well before the second world war.
Basically, the Falken Tire model line is an exceptional low cost value that yet integrates high level technology to provide important performance tire attributes such as, assymetrical and directional tread patterns, dry and wet handling, as well as, overall cutting edge design and quality, at a reduced cost.
For twenty years I have had many Falken tires installed in all my vehicles from sport sedans to IROC Camaro's, GTA 5.7L Firebirds, Trans Ams, Mustangs, and, even mounted on some of my beloved Corvette C4's and C5's.
And, for those of us who utilize performance vehicles as our daily drivers, I am continually amazed by the even tire wear and longevity that I am able to extract from the Falken Tire line. My daughter was able to obtain over 50,000 miles (with consistent and proper tire maintenance) on her Falken Ziex's commuting for four years to the University. This is extraordinary because the Falken Ziex's are a "Z-Rated" high performance tire, and, therefore, do not have the "mileage warranty" that a common traditional passenger sedan tire would.
The performance, cornering, and, wet and dry handling characteristics are more than acceptable. In fact, I like the directional tread pattern constructed into the Falken tire. Many other equivalent brands had larger and more "square bead block" tread designs that are conducive to high road noise and poor handling in wet conditions. Hence, I have kept with the Falken Tire as my low cost directional tread performance tire. Therefore as an o.e. tire size equivalent, Falken tires offer a great low cost alternative.
Best Wishes,
Eden
Click the yelow box for specs...
http://www.falkentire.com/tires_451.htm
I had Falcons on my C4, they wore well.
