Guage Lights
Old Jul 28, 2005 | 04:55 PM
OUR97's Avatar
OUR97
Default Guage Lights
When the C5s came out I was wowed by the instrument cluster lighting up as the door is opened. Since then, I have purchased a 97 and have had it 3 years now. Great car! My guages do not light up as I remember the showroom car doing. I have scoured the Service Manual for a clue and can't find anyone who can help me determine how to make it work as it should. Anyone got an answer?
Old Jul 28, 2005 | 05:01 PM
Humy's Avatar
Humy
I don't think it is supposed to do that
Old Jul 28, 2005 | 05:08 PM
OUR97's Avatar
OUR97
I have talked to other C5 owners and one guy said it works intermittently. Others don't notice it.
Old Jul 28, 2005 | 05:13 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
With the "approach light" setting on the DIC. The fogs will go on also
Old Jul 28, 2005 | 05:33 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Considering there are 2 black, fluorescent bulbs lighting the gauges, I don't know why they would be dimmer? I would understand if they flickered, or just didn't light up at all, but fluorescent lights don't usually "dim".
That's odd .... unless they just aren't fully lighting up (you'd see a flickering kind of pattern), in which case, maybe try and track down replacement bulbs and see if that works. If you are half way mechanically inclined, you can change those out w/o a problem.
Old Jul 28, 2005 | 05:35 PM
jawzforlife's Avatar
jawzforlife
my gauges lights turn on when I get in the car and before I put the key in.
Old Jul 29, 2005 | 02:08 PM
javamon's Avatar
javamon
Mine too.
Old Jul 29, 2005 | 02:20 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Also mine stay on after i shut it off and get out.
Old Jul 29, 2005 | 06:50 PM
ebubman's Avatar
ebubman
ditto here. they come on when i open the door & when we park the car, they stay on. in both cases, on-time is circa 30 seconds. i believe this is specifically mentioned in the om. bub
To Guage Lights
