Newbie tire changing question
Old Jul 28, 2005 | 08:09 PM
BLUC5's Avatar
BLUC5
Default Newbie tire changing question
I am almost too embarrassed to ask this question. After 35 years of driving and changing tires on cars this is the first time I have been intimidated by the task. Just how fragile are these cars (a 2002 C5)? Okay, I bought the pucks (installed them in the former tie down areas as described), the jack stands, and I bought the Craftsman floor jack that many here recommended. I have looked at the jacking tips and the car manual. I guess I still need the boards to drive the car up onto to reach the front crossmember. Here is the dumb question...you jack up the car and you lower the weight of the vehicle onto the jackstands that are placed where the pucks are installed in the former tiedown areas....so why can't you jack the car up at these points too?
Old Jul 28, 2005 | 08:19 PM
Corvette00Car's Avatar
Corvette00Car
Yes you can jack them up here. I use a hydrolyic jack with the hockey puck (just one). The whole idea is to make sure you don't hit the wrap around from the door sill.
Great car isn't it.
Old Jul 28, 2005 | 08:32 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Great car isn't it.
No issues with jacking the car up at the jack points.
Old Jul 28, 2005 | 08:45 PM
99 TorchRed's Avatar
99 TorchRed
The puck placement area is recessed in (up) a slight bit from the wrap-around body sill. If you were to lift on that jacking point using a standard jack without the extension that a "puck" offers (or similar item) you stand a good chance of damaging the wrap-around sill. Aftermarket companies also offer an adapter that fits in many hydraulic floor jacks that mates with the jacking points in your C5. (It replaces the lifting cup that is standard with those floor jacks).
Old Jul 28, 2005 | 10:00 PM
LoneStarFRC's Avatar
LoneStarFRC
I agree that you can jack from this location too, but unless I just have to (flat tire on the side of the road), I prefer the "jack from the center" method. That way the car stays level plus you can put two jackstands under the "jacking points" at once. I like to drive up on ramps then jack the rear up and put on jackstands.
Old Jul 28, 2005 | 10:10 PM
BLUC5's Avatar
BLUC5
Default Thanks!
I appreciate the quick feedback! Thanks...And yes the car is great!
jrose7004's Avatar
jrose7004
Old Jul 28, 2005 | 10:22 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
How about rocker rails, do you need pucks with this setup?
Old Jul 28, 2005 | 11:29 PM
DirteeDave's Avatar
DirteeDave
No, in fact most pucks won't fit in the slot after the rocker rail install because the rail partially covers the slot.
Old Jul 29, 2005 | 10:13 PM
BLUC5's Avatar
BLUC5
Default Now what to do? Rounded lugs
Thanks for all of the advice. I managed to lift the car and clean up my hats on my front rotors. No problems, again thanks to all the great advice. I went to the back and started to break the lugs loose on the right rear and found two that were nearly rounded off so now I can't get my right rear off. Any advice for this condition?
Old Jul 30, 2005 | 12:52 AM
ECV-Tony's Avatar
ECV-Tony
What are you using to get your lugs off with? I use a cordless impact driver and I knock all my lugs off like a nascar pit crew. The hammering of an impact tool will certainly loosen those stubborn lugs. Someone will post another way soon. When you have to put the lugs back on use a quality torque wrench and tighten them to 100lbs.
Old Jul 30, 2005 | 08:39 AM
You can jack the car up in the locations you mention - just use the pucks so the pad of the jack doesn't come in contact with the lower portion of the rocker panel.
To Newbie tire changing question
