leak???
Old Jul 29, 2005 | 12:26 PM
DD's02's Avatar
DD's02
Default leak???
3 or 4 drops of what looks/feels like motor oil on the floor of my garage. underneath the REAR of the car, just about the center. what could be leaking?
Old Jul 29, 2005 | 12:33 PM
BlueDragon's Avatar
BlueDragon
Prolly a rear seal. Could be axel, very common problem. Next step to put her on the rack and trace it back.
Old Jul 29, 2005 | 12:34 PM
bekdad's Avatar
bekdad
Likely leaking from your driver's side differential case access cover. Join the club.
Old Jul 29, 2005 | 12:36 PM
Could be the differential seal on the side or it could be the seal between the tranny and the differential (I've had both things happen to mine). Pretty common on the differential leak.
Old Jul 29, 2005 | 12:44 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
differential fluid. mine is leaking as well, although it sometimes goes a month or more without seeing any drops on the garage floor. as is stated above, the leak could be the side cover (relatively easy fix) or seal between tranny and diff, which is more cumbersome. have someone, preferably not a dealer check it out. the dealers love to screw people on problems like this
Old Jul 29, 2005 | 07:54 PM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
Common problem. Mine's at the dealer now getting fixed....
Love that extended warranty!
Old Jul 29, 2005 | 08:07 PM
C5naples's Avatar
C5naples
Common problem. Rear differential leak. Mine only leaked after driving at interstate speeds. In town it would never leak. I think it is a $500 repair at the dealer
Old Aug 3, 2005 | 10:30 AM
C5sRule's Avatar
C5sRule
So after the repair has been completed, what prevents it from
happening again? Have the repair materials been improved? I am
now experiencing the same problem and was wondering where to
get it repaired.
Old Aug 3, 2005 | 10:33 AM
Flying Ace's Avatar
Flying Ace
I believe they have improved the seals and gaskets for both the transmission and the diff.
Old Aug 3, 2005 | 11:43 AM
Bandit1's Avatar
Bandit1
Yep, me too
Old Aug 3, 2005 | 01:36 PM
Kanon's Avatar
Kanon
If it does end up being your ouput shaft seal, these instuctions are pretty easy to follow:
http://www.cajundude.com/outputshaftseal.htm
Only took me about 3 hours to do the job, and those instuctions above are easier than what the service manual suggests.
Old Aug 3, 2005 | 02:01 PM
davee01's Avatar
davee01
I think mine is leaking as well. I am visiting the dealer next week (Still not modded enough to void warranty) so will have them look. They also have a speaker to replace....
Old Aug 3, 2005 | 06:05 PM
C5sRule's Avatar
C5sRule
Thanks for the responses.
To leak???
