Engine oil level, anyone else have this problem?
Old Jul 29, 2005 | 05:39 PM
Jims2001's Avatar
Jims2001
Default Engine oil level, anyone else have this problem?
When changing my engine oil for the first time at 4000 miles I could not get a consistent dip stick reading after I put in the recommended 6.5 quarts plus just a little more trying to get a accurate reading. After a couple thousand miles I still cannot get a accurate reading on the dip stick. It will read about half way between add and full and then the oil will cover half the width of the dip stick past the full mark, just like it did when I changed it for the first time. I was afraid I had too much oil when I changed it for the first time now not sure I have enough. Anyone else experience this? Want to know what to do before I drive it again.
Old Jul 29, 2005 | 05:43 PM
georgec114's Avatar
georgec114
Some have roughed up the area of the stick with some emery cloth.
I always found the back of the stick gave a more accurate reading.
Old Jul 29, 2005 | 06:21 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
Have the same problem with mine!
Old Jul 29, 2005 | 07:57 PM
NoWay's Avatar
NoWay
Common problem. Very poor dipstick design according to the technician - at least on the 2001. Assume it is the same on all LS1s.
Old Jul 29, 2005 | 09:18 PM
Beezvette's Avatar
Beezvette
I have had all of those problems. Check the oil in the am after it has been sitting - that works OK. Concerning the amount of oil, lots has been written on the forums. With the 2001, if you add 6.5 quarts, you'll barely be above the hatch marks and in no time the "check oil" DIC will go on. 7 quarts fills it to about 3/4 up the hatch marks. Some, including GM, are adamant that you must not exceed 6.5, but if you have a 2001 and want the DIC to stay off, you have to put 7 in.
Old Jul 29, 2005 | 09:50 PM
DaBoz's Avatar
DaBoz
Sucks don't it??
Old Jul 29, 2005 | 10:00 PM
Cpe04's Avatar
Cpe04
Half way between add and full is fine.If you want to get rid of the oil that covers half the dipstick do this:Pull out the dipstick and then wait about 2 or 3 minutes,then reinsert the dipstick.This allows time for the oil which has transfered from the dipstick to the tube to drain back down.You'll get a nice clean reading.
Old Jul 29, 2005 | 10:49 PM
HOTSOSS's Avatar
HOTSOSS
You must be using 10W30. Try 5W30 next change.
Old Jul 29, 2005 | 10:51 PM
Bounty Hunter 6
I always use 5w30 and have that problem. When I got the oil changed last time, they added 6.5 quarts and I got the low oil level light consistently. When I would check the dipstick it never was very clear so I added just a half quart and bingo, no more DIC warnings.
Old Jul 29, 2005 | 11:07 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Sorry to hear of the problem...I have never had an issue.
Micah
Old Jul 29, 2005 | 11:44 PM
GrayC5's Avatar
GrayC5
You might give the following from the C5 Tech Tips section of the Forum a try: How to Check Oil Level.
Good luck.
Old Jul 30, 2005 | 08:45 AM
When I have this problem, I will also check the back of the dipstick. I can usually get a good reading that way.
Old Jul 30, 2005 | 06:03 PM
Jims2001's Avatar
Jims2001
Thank for all your help guy, would not want to be without the Fourm.
Old Jul 30, 2005 | 06:19 PM
Jims2001's Avatar
Jims2001
Having trouble with my ssss! Thanks guys.
Old Jul 30, 2005 | 06:22 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
2000 here 7 qts when i change the oil per my vette tech !
Old Jul 31, 2005 | 09:30 PM
javamon's Avatar
javamon
Hell...I don't think Chevy has ever cared about fixing this. My '93 S-10 along with with my '02 'vert are hard to read. Reading the back of the stick seems to give me the most accurate reading on both.
Old Aug 1, 2005 | 09:24 AM
PEW01's Avatar
PEW01
Micah
To Engine oil level, anyone else have this problem?
