i've had the car for 2 weeks...i'm generally ignorant.
I'm getting a LOW COOLANT warning.
What do i need to do?
what kind of coolant...etc?
water to coolant ratio??
If there is sufficient coolant in the tank, then you have an indication problem. At the bottom of the tank there is a plug that plugs into the integral sensor in the tank. Insure that is plugged all the way in, and/or check it for corrosion. If you need a new sensing element, the tank must be changed to fix it. Also, some people bleed the system after adding coolant if is is quite low. The question is: Where did it go? Water pump? Hose? (Dexcool).
