Momo Shift knob removal?
Old Jul 30, 2005 | 06:00 PM
NoOne's Avatar
NoOne
Default Momo Shift **** removal?
ok, I'm baffled. I've found some directions regarding some pins but they are inside the holes and there is no corresponding hole to 'knock' them out with.
How in the hell does this thing come off?
I have my new leather boot and I'm dying to put it on.
Old Jul 30, 2005 | 06:24 PM
Patches's Avatar
Patches
The Momo **** I once used had two allen setscrews holding it in.
Old Jul 30, 2005 | 07:08 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
On mine there is an aluminum cap that threads off the bottom of the ****.
Once you unscrew that, there are 3 small set screws that fasten it to the shifter handle. Loosen those, and the **** should lift straight up off the shifter. You'l also find a rubber adapter bushing that's slipped over the shifter threads, don't lose this if you plan to re-use the ****.
Old Jul 30, 2005 | 07:19 PM
NoOne's Avatar
NoOne
Ah...well seems that those set screws were put in with an impact gun, no head left on them at all, thats why I was confused.
hmmm....
To Momo Shift knob removal?
