Cruise control kicks out...
Old Jul 31, 2005 | 10:58 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Cruise control kicks out...
Ever since I had a heavy duty clutch installed a few years ago my cruise control kicks out-at 40 MPH in 6th (I have 3.90), going down hills, and when my engine isn't tuned right and bucks at low speed.
I remembered a recent post about buttons (switches) at the brake and clutch pedals, so today I drove at 40 under the conditions that it kicks out but I held my foot under the clutch pedal and pulled up and it doesn't kick out under that condition.
What do I need to do? I mostly don't work on my car.
May the BOOST be with you!
Roy
Old Aug 2, 2005 | 09:11 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
You have to adjust & clean those switches/buttons that rest against the pedals
Old Aug 2, 2005 | 09:18 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
I had the same problem. For a quick fix for mine I added one a small felt stick on pad to the back of the pedal so the switch would make contact with the pedal.
Old Aug 3, 2005 | 12:35 AM
7.0sc SuperVette
Default Thanks guys...
Sounds simple enough that even a Real Estate Broker could do it!
Roy
To Cruise control kicks out...
