Glad it worked for you! I installed the kit on my '04 and didn't have the same luck Maybe they changed the flasher unit in '04 or maybe mine is just a POS, but the lights only blink correctly when the engine is not running. Start the car, and they blink inside-inside-outside, instead of the expected inside-outside sequence. WebElectric is VERY fast with their responses via e-mail, and he has never seen this happen before (I sent him a video). He is also sending me (at no charge) some load levelers to attach to my wiring and hopefully fix the whole thing. I love the look, but why is it MY car that it doesn't work on???
Grimlins????? Hope it works out for you. The WebElectric sequenser worked fine on my '04. I agree, WE has dynomite customer service.....
THEY WORK! WE customer service rocks like old Van Halen. Several times I e-mailed back and forth trying to solve my problem, and tonight I had some free time and WE's instructions, and my sequential lights now work perfectly. I had to install a couple load equalizers in the circuit (one between the red and black wires on each side) and the kit works perfectly now. WE sent me the load equalizers free of charge. Glad I stuck with it and didn't just give up and take it out when I hit a snag - the set-up looks terrific. And thanks a ton to Not-Mee who worked several times on this, as he has the cojones to tear into electrical work, unlike me...
Glad you slew the gremlins Now, do you have the WE pulser for the center brake lite? I just got one a week or so ago and it's a breeze to install. Now I really want to convert to LED's ( as I've posted before) once I fully understand what's required to ensure they will work with the sequencer (don't want to give that up).
When I gather up the courage to open up the rear end of the car once again, I'll do the third lite mod.
I'm really not selling, but it's quick and easy. Just remove the license plate, reach up and unplug the center lite, plug in the pulser into the harness and replug into the lite. Reinstall the license plate and you're pulsing...... Actually, the hardest part was removing the license plate frame....... Oh well....
