Removing wheel weight adhesive
Old Aug 1, 2005 | 07:09 AM
rws.1's Avatar
rws.1
Default Removing wheel weight adhesive
I just acquired a 2001 Vert with stock wheels.
The former owner put new tires on it. In the process they new tires needed rebalancing. The tire shop removed the old stick on weights that were mounted on the front of the wheel ( visible ) now there is an unsightly mess from the original tape backing and glue from the stick on weight. Anyone else had this problem? I know these adhesives are solvent based and I'm sure I will find something to take it off, but I don't want to wreck the clearcoat in the process.
thanks
Old Aug 1, 2005 | 07:41 AM
cenzo's Avatar
cenzo
Skin-So-Soft smells good too.
Old Aug 1, 2005 | 11:25 AM
rws.1's Avatar
rws.1
The Avon product? Hmmm... never would have thought of that.
Old Aug 1, 2005 | 11:59 AM
cenzo's Avatar
cenzo
Rich, check in the vanity or medicine cabinet. You probaly already own some. There's other stuff around like goo-be-gone etc. but you can't use that stuff for anything else.
Old Aug 1, 2005 | 12:23 PM
diyguy's Avatar
diyguy
Dab it good w/ WD-40 - let it soak 3-5 minutes, scrape off with credit card edge. Wipe clean.
Old Aug 1, 2005 | 12:33 PM
Bandit1's Avatar
Bandit1
thanks
I use 3M Adhesive Remover. Can get it at Pep Boys, Kraegen, Checker Auto...........
Old Aug 1, 2005 | 12:56 PM
zonsolo's Avatar
zonsolo
I'm not sure how goo-gone will hurt a clearcoat finish, but I used it on chrome to remove the black double sided tape on my wheels.
Let it soak for 3-5 minutes and brushed it off with an old toothbrush. Worked flawlessly. First application removed the foam, 2nd removed the goo.
Old Aug 1, 2005 | 05:36 PM
Z0SLIK's Avatar
Z0SLIK
YEP!!
Old Aug 1, 2005 | 06:30 PM
That works great. Did that on my original wheels to my car when I sold them.
Old Aug 2, 2005 | 05:48 AM
rws.1's Avatar
rws.1
Thanks guys
Rich
Old Aug 2, 2005 | 08:43 AM
michach1's Avatar
michach1
My friend found a creative way of doing this last weekend. Drive 3 20 minute sessions at Summit Point Raceway. Park your car so that the wheel weights are at the top of the wheel. Wait 2 minutes and watch the weights and the adhesive fall off right before your eyes. Funniest thing I had seen in a while.
In other words, just drive your car like mad and heat up the wheels, brakes, and rotors. This stuff will just melt off.
Old Aug 2, 2005 | 02:04 PM
Red-N-Ready's Avatar
Red-N-Ready
This stuff is great!!! WILL NOT hurt your paint or clearcoat! I've used it for years.
To Removing wheel weight adhesive
