Problem with key
Old Aug 1, 2005 | 10:44 AM
2002 red conv's Avatar
2002 red conv
Default Problem with key
Does anyone have a problem when they pull their key out of the ingition the doors won't unlock. I brought mine to MacMulkin of Nashua NH 3 times for this problem, but because it works sometime and other times it don't they can't fix it. I am thinking about replacing the cyclinder on my own just to fix it. Thanks
Old Aug 1, 2005 | 11:17 AM
DAWS C5's Avatar
DAWS C5
This is a bit of odd coincidence. My door locks never unlocked when the key was pulled. Recently had power door lock problem that was fixed by replacing the left door control module. All of a sudden I had a new feature - door unlocks when key pulled.
Anyway, I suspect there is a communications problem between door control module and body control module. Should be some codes set.
Old Aug 1, 2005 | 11:20 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes, I also had the lock replaced. The tiny pin in the lock gets stuck. I sprayed the key with some electrical silicone and had good luck so far.
Good luck
Old Aug 1, 2005 | 01:10 PM
2002 red conv
Thanks and tell me the Red Sox don't kick _ss
To Problem with key
