Dashboard light problem-help!
Old Aug 2, 2005 | 12:53 AM
mambovette's Avatar
mambovette
Cruising
Default Dashboard light problem-help!
Damsel in distress.
Dashboard lights up then goes out on an
intermittant basis. The fuse for the dashboard
light(s) is fine. My mechanic is having a problem
diagnosing it and I would rather stay
away from the stealer dealers.
Could it be the light switch itself? My C5 has
78,000 miles and is otherwise in perfect repair
Old Aug 2, 2005 | 10:36 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Is it all the dash lights ... DIC buttons? Or just the gauge cluster (speedo, tach, fuel, etc)?
Old Aug 2, 2005 | 10:39 AM
college_guy's Avatar
college_guy
I had this problem in my 94 suburban. It might not be the same due to being a totally different vehicle, but it was the dimmer switch that we had to replace (which ended up being the whole headlight switch itself). I hope this helps!
Old Aug 2, 2005 | 01:39 PM
mambovette's Avatar
mambovette
Cruising
It is only the dashboard cluster of instruments
It works -- and then five minutes or so later
is goes out. Is there a light bulb that just
lights up the gauge cluster?
Thank you!
Old Aug 2, 2005 | 01:45 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Thank you!
GM uses two black light to illuminate the dash. In the picture below you can see the black light on each side.
Old Aug 2, 2005 | 01:51 PM
mambovette's Avatar
mambovette
Cruising
Do you think it is the lights or the dimmer
switch on the side of the dashboard?
Old Aug 2, 2005 | 04:46 PM
LV_2_XLR8's Avatar
LV_2_XLR8
Those particular lights are flourescent, which are not dimmable like conventional dash lights are. They achieve a dimming effect by modulating the power to the lights, causing them to go on and off faster than the human eye can detect. They vary the percentage of on time, to off time, to achieve the dimming effect.
I would suspect something in the modulator circuit, but it wouldn't hurt to pull the cluster and check the connections before replacing the modulator. The dimmer switch on the left side of the cluster also dims the rest of the cockpit lighting (radio, temp controller, etc.) If they still dim when the cluster doesn't, then I would suspect the dimmer switch itself is not the culprit. Once you pull the cluster, you will see the high voltage modulator that powers the cluster lights. (there are high voltage warnings all over it) I would center my suspicians there. This sounds harder than it really is. I've had my cluster out a dozen times.
Good luck, intermittent problems are clearly the most difficult to troubleshoot.
Old Aug 2, 2005 | 05:07 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
Damsel in distress.
Looking for a solution...
...or a knight in shining armour who has the solution...?
do the gauges work when the lights go out...?
...could be as likely a loose connection...
Old Aug 2, 2005 | 06:14 PM
mambovette's Avatar
mambovette
Cruising
Thank you LV2XLR8!
Then it should be either the dimmer switch
or the modulator circuit. My mechanic will love you for it.
To Dashboard light problem-help!
