What makes me hot!!
Old Aug 5, 2005 | 06:55 AM
WKMCD's Avatar
WKMCD
Default What makes me hot!!
Beautiful morning here in Northern VA. Driving in with the top down and the radio up. It's 74 and clear and I'm running about 50MPH. I look down and see that the temp guage is pegged. I immediately pull over and raise the hood. No hot sounds (creaking, etc) and the recovery tank is fine. Level is good also. I check codes and I'm getting a P0118 code. Clear code and same thing. Guage is sweeping correctlywhen the ignition is turned on. As soon as I start it, it pegs again. I don't think I'm really running hot, but....
Help me please.
Old Aug 5, 2005 | 07:10 AM
Dark-Knight's Avatar
Dark-Knight
Pull off your air box and radiator shroud, sounds like you got a platic bag or other debries stuck against your cooling system.
About two weeks before I put on my Hurricane I ran over one of those damn plastic bags and did not see it come out the back. I was near my favorite tuner, 21st Cent MC so I pulled in and we put her on the rack. No bag to be found. Fast forward two weeks... Patrick pulls off the shroud for the Hurricane install and there is the damn bag! Stuck against the radiator
There was other no way to see it under the car or looking under the hood.
Good luck in solving your overheating problem.
Old Aug 5, 2005 | 07:15 AM
WKMCD's Avatar
WKMCD
That's the problem. I don't think it's really over-heating. It appears to be a sensor or guage problem.
Thanks, I will check though.
Old Aug 5, 2005 | 07:57 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
At that outside temp and that speed...
...I would suspect radiator full of debris...StuzVette problem resolved last week...
...sensor problem...or thermostat issue...
what does pegged mean...?
Old Aug 5, 2005 | 08:06 AM
WKMCD's Avatar
WKMCD
Definition: Pegged - Adverb used to describe a temperature guage that advances to the extreme limit immediately upon starting the car. Not almost all the way - all the way against the stops.
Old Aug 5, 2005 | 09:59 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
check to see if temp sending unit wire didn't come off or if it is grounding out on somthing. Or it could be a bad sending unit.
Old Aug 5, 2005 | 10:17 AM
Postergeist's Avatar
Postergeist
I just went through the same thing with my car. There were some air bubbles in the coolant line. Bled those off and didn't have the gauge problem again.
Old Aug 5, 2005 | 10:18 AM
ttaylor's Avatar
ttaylor
Just an idea here. What did the other guages read? Like the DIC or the HUD. I would think if the car was really that hot you would have got other message also, like on the DIC. Jus an idea.
Old Aug 5, 2005 | 10:31 AM
Tino's Avatar
Tino
Good point ...
Old Aug 5, 2005 | 10:41 AM
yellow01's Avatar
yellow01
Actually 'pegged' is an adjective, not an adverb. Or, it could be a past tense verb, it 'pegged when started'.
Old Aug 5, 2005 | 10:43 AM
Postergeist
When I was having problems with my temp gauge, there were no DIC messages, such as low coolant.
Old Aug 5, 2005 | 01:00 PM
I'd guess the temp sensor went bad. Hope you get it resolved.
Old Aug 6, 2005 | 12:42 PM
WKMCD's Avatar
WKMCD
Where is the temp sensor?
Old Aug 6, 2005 | 01:17 PM
VLVETTE's Avatar
VLVETTE
Old Aug 6, 2005 | 01:50 PM
Freestyler's Avatar
Freestyler
LOL
actually that made me laugh
Yes, an adjective of course of course
Old Aug 6, 2005 | 03:07 PM
WKMCD's Avatar
WKMCD
Found it. I guess I bumped the temp sensor when I installed the MSD wires the other day. It took a couple of days to work itself free and was unplugged. OK now. Thanks
Old Aug 6, 2005 | 03:41 PM
VLVETTE's Avatar
VLVETTE
As we say in SoCal BITCHEN! Now go drive that badboy
To What makes me hot!!
