DIY Door Supports
Old Aug 8, 2005 | 12:36 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Default DIY Door Supports
Couldn't see all the $$ for door braces, $15 worth of stuff from Lowe's, an hour or so in the garage and....
Old Aug 8, 2005 | 03:03 PM
b98's Avatar
b98
this is a very easy mod. to do.
Old Aug 8, 2005 | 03:22 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
They look great!
So ... you gonna share with the rest of the class? We need details please ...
Old Aug 8, 2005 | 03:35 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Very nicely done, those really look good!
Old Aug 8, 2005 | 03:49 PM
QuikZilver's Avatar
QuikZilver
Originally Posted by MyVetteDream
They look great!
Old Aug 8, 2005 | 06:50 PM
coast7's Avatar
coast7
I'm game...tell me why I need door supports
Old Aug 8, 2005 | 06:56 PM
PRIMAL's Avatar
PRIMAL
MMMM Xtra air flow when driving ??
Old Aug 8, 2005 | 07:27 PM
CUlookin's Avatar
CUlookin
Awesome man!! They're great for shows so that no one can get into your car and you can show off your interior!
Old Aug 8, 2005 | 07:56 PM
VLVETTE's Avatar
VLVETTE
They look great!
Old Aug 9, 2005 | 08:38 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
What you need:
1 piece of 1/2" X 48 square bar from Lowe's, about $8
2 SS 7/16 X 1 3/4 bolts
2 SS 7/16 nuts
2 SS 7/16 acorn nuts
I made mine about 19" long, you can make the length whatever you want. Cut 2, 19" lengths of square bar. Mark the location of the door striker pins on the upper and bottom side of the bar, grind one upper and one lower side, 3/8 x 1/4, to match the pin locatioins. You need to be able to insert the bar between the pins and lift it up or push down for the pins to fit into the slots, this holds the bar inplace at the door striker. Place the door where you want it to be in the open position, come out about 7 1/2 " from the end with the slots in it, bend the bar so it's parrell to the latch in the door. You might also have to make a vertical bend, up or down, to allign the bar with the door latch. Make a mark where the door latch is and drill a whole to put the 7/16 bolt through. Install the bolt, regular nut on one side and acorn nut on the outside for a finished look. I buffed these to make them look better. You can paint, powder coat or have the bars chromed....pretty simple to make, just get your bends correct. To install, lock the striker end in place, lift the door handle and slide the bolt in the door latch, to remove, pull the door handle and slide the bolt out. Good Luck....
Old Aug 9, 2005 | 08:54 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Forgot, pic of finished bar on work bench....
Old Aug 9, 2005 | 08:57 AM
GB Vette's Avatar
GB Vette
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
Hey Ken, isn't that a 1/4" bolt with a 7/16" head on it?
Old Aug 9, 2005 | 09:25 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
thanks KC...nice writeup...StuzVette deserves one in polished aluminum me thinks
Old Aug 9, 2005 | 09:37 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Daaamn...you're good, what can I say, old brain cells just short out sometimes....
Old Aug 9, 2005 | 11:32 AM
MyVetteDream
Thanks KC! This needs to go to DIY TECH or something ...
These things are a couple of hundred bucks from if you buy 'em ...
Dave
Old Aug 9, 2005 | 11:39 AM
C6 NOIR's Avatar
C6 NOIR
St. Jude Donor '03-'06-'07-'08-'09
Nice write up. Thanks for the details.
To DIY Door Supports
