Took my 01 coupe to get its new Nitto 555's installed yesterday. Took it to the GM Dealer because I wanted it to be done right.
Tires are awesome but now I have a Tire Monitoring System nightmare. My right front reads Flat - which gives me an error message every few minutes. My rear tires don't read at all.
The dealer tried for an afternoon and all of today to reprogram. Used the Tech 2 tool and everything. Said I had a right front sensor (the one reading flat) needs replacing.
I can't see how one sensor can bring back the rears??
Sounds like you need to find ANOTHER dealer. One that is familiar with GM's products.
The tire sensors should be able to be reprogrammed by someone who is aware of the correct procedure...unlike YOUR dealer.
