Windshield wet
Old Aug 10, 2005 | 12:38 PM
TAGVETTE's Avatar
TAGVETTE
Default Windshield wet
Recently, when I stand on the accelerator, I get just a little bit of windshield washer fluid running up my windshield. Just a drop or so, but it happens everytime.
Old Aug 10, 2005 | 12:44 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
I've had that occur at track days, but not in normal driving. I always thought it just occurred when you drove fast enough that the underhood pressure forced a bit of fluid out.
Old Aug 10, 2005 | 01:02 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I call them tears of exhilaration, because your Vette is happy it is being driven the way it was intended to be
The fix is part number 22102237, it should be covered under the bumper to bumper warrantee.
Old Aug 10, 2005 | 02:45 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Think there's a service bulletin out about installing a check valve inline for that complaint.
Old Aug 10, 2005 | 02:59 PM
Y2KC5NBM's Avatar
Y2KC5NBM
Cruise-In V Veteran
Senior Member
Been there done that. I installed the check valve with the part number listed above. The problem is that the hose coming from the windshield washer fliud motor is a hardened plastic line. It is supposed to slip over one of the male ends on the check valve. Well this doesn't work. The male end of the check valve is to big to fit into the hardened plastic hose. No matter how much stretching you try will get the hose big enough to fit over the check valve end. Luckily I had some rubber vacuum tubing laying around. I cut it to the same length as the hardened hose and used in place of the hardened plastic hose. This resulted in having to remove the windshield washer solvent tank to get to the motor, but was very easy. Once everything was completed I have to more tears of exhileration.
The down side to this fix is that my passenger side washer sprayer no longer works. I don't think that their is enough pressure to push it through to the other side. Oh well, who cares about the passenger windshield right?
Old Aug 10, 2005 | 04:13 PM
Bullet's Avatar
Bullet
I have noticed some blue stuff under the wipers on mine too - think I'll just siphon the tank. Does the blue water taste like blueberries?
Old Aug 10, 2005 | 04:53 PM
b98's Avatar
b98
Try using heaver water, or the new thick stuff, works great.
Old Aug 10, 2005 | 05:00 PM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
[QUOTE=StephenT]I call them tears of exhilaration, because your Vette is happy it is being driven the way it was intended to be
QUOTE]
I am gonna give mine a heart attack.
Old Aug 10, 2005 | 05:09 PM
steve8's Avatar
steve8
Same thing happened to me just the other day for the first time. I'll ask the dealer if he can just give me the check valve if it persists. I have an 04 if that matters?
Old Aug 10, 2005 | 05:10 PM
Humy's Avatar
Humy
runny nose with a swift kick in the azz
Old Aug 10, 2005 | 05:14 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I get it several times a day when I go WOT
Old Aug 10, 2005 | 06:02 PM
VetteSiNz's Avatar
VetteSiNz
I wonder why I always get the Low Washer Fluid code.....now I know the reason.
Old Aug 10, 2005 | 06:11 PM
azmusclecar's Avatar
azmusclecar
is it tears? Or is the Vette excited? As in premature fluid dispersion?
Old Aug 10, 2005 | 10:18 PM
Dark-Knight's Avatar
Dark-Knight
Weeping washers is common, had a warranty fix done on mine. Now only one does it. Dumb dealer, gotta go back....
Old Aug 10, 2005 | 10:29 PM
ls1vette97's Avatar
ls1vette97
I read this post this morning, and have never had a problem with it before. Tonight I took a ride on the wild side and it happened?Bad Karma, or is everything contageous on this forum?
Old Aug 10, 2005 | 11:30 PM
The check valve is one solution, but you can also just not fill the reservior up so full.
To Windshield wet
