Service Vehicle Soon
Old Aug 10, 2005 | 09:18 PM
1BAD97VETTE's Avatar
1BAD97VETTE
Default Service Vehicle Soon
when i turn my car on in the lcd screen it says service vehicle soon... it just recently started doing this... at does not have the check engine light on though... but i was just wondering if this was something that came on every so many miles... and i was wondering if there was a way to reset it... if not heck what do i need to service...
THANX
Old Aug 10, 2005 | 09:34 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Probably an alert to go in for regular service. How many miles?
Old Aug 10, 2005 | 09:36 PM
1BAD97VETTE
42k... well how can i reset it lol.. i ususally do my own service work
Old Aug 10, 2005 | 10:30 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
SERVICE VEHICLE SOON: If this message appears
on the DIC, there may be an electrical or another system
problem with your vehicle. Have your vehicle checked
by your dealer if this message keeps appearing.
Old Aug 11, 2005 | 06:48 AM
mikestuff's Avatar
mikestuff
Straight from the manual. Mine has come on intermittently for about 2 years now.
Old Aug 11, 2005 | 07:24 AM
Silver98's Avatar
Silver98
There are a number of DTCodes that will cause the SVS / SES message. Check out the codes on the DTC and post them here. Someone will be able to help out.
Old Aug 11, 2005 | 08:42 AM
jedicowboy's Avatar
jedicowboy
Electrical problem that probably isn't that big of a deal. It could be anything from a broken stearing sensor (usually done by clowns at at non-GM alignment shop) to a BCM going bad. Check you codes and someone will hook you up.
Old Aug 11, 2005 | 02:23 PM
1BAD97VETTE
hmm well i can check them at advance.. but will it show any if the check engine light is not on... its only saying service vehicle soon in the DIC
Old Aug 11, 2005 | 03:53 PM
Silver98's Avatar
Silver98
Check the codes through the DIC! IF the code is suffiexed with 'H', the condition is no longer present, if it is suffixed with 'C' or 'HC', then the condition is present.
Old Aug 11, 2005 | 04:19 PM
Red-N-Ready's Avatar
Red-N-Ready
check your email!
To Service Vehicle Soon
