Having a flat with run flats??
Old Aug 11, 2005 | 03:16 PM
Fubarred1's Avatar
Fubarred1
Default Having a flat with run flats??
The tire pressure in my RF (right front) tire is losing about 10lbs of air per week. How is this %*@&ing possible with run flats?
Old Aug 11, 2005 | 03:20 PM
DeJay's Avatar
DeJay
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
You can still get a flat tire w/runflats. The thing is you can drive on them until you get to a tire repair shop or tire dealer. They can be repaired provided the leak is not on the sidewall.
Old Aug 11, 2005 | 03:23 PM
TruUndrtkr's Avatar
TruUndrtkr
I'm having the same problem with my RR tire..
Old Aug 11, 2005 | 03:40 PM
HummelS's Avatar
HummelS
Old Aug 11, 2005 | 03:46 PM
Dave1998's Avatar
Dave1998
I had the same problem. I closely examined the tire and found a nail in it. As I was interested in seeing how the runflat works, I pulled out the nail, and the remaining air excaped. I then drove the car about 10 miles to a Goodyear dealer and had it repaired properly from the inside,
meaning the tire is removed from the rim.
You likely have something in your tire
Old Aug 11, 2005 | 05:21 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
You might also check for a valve stem leak........ that has happened to me in the past....
Old Aug 11, 2005 | 05:33 PM
Having runflats doesn't mean your tire can't lose air. It just means that should you get a puncture, you can drive the car up to the maximum distance with little or no air instead of having to stop and change the tire.
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Old Aug 11, 2005 | 05:44 PM
ebubman's Avatar
ebubman
since screws & nails occasionally find tires, for my money, i'm sticking with run flats. bub
Old Aug 11, 2005 | 07:03 PM
VetteSiNz's Avatar
VetteSiNz
I paid $58 for that type of repair and Goodyear scratch my rims. Finally I replace all my runflats with Michelin PS A/S.
Old Aug 11, 2005 | 07:06 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
This might help.
http://www.infostuff.com/carstuff/newstuff.htm
I'd suggest you check your tire for a nail, screw or other foreign matter. Then put some dishsoap in solution in water and wipe it around the valve stem and see if you have a leak at the o-ring.
Paul
Old Aug 11, 2005 | 07:39 PM
99 TorchRed's Avatar
99 TorchRed
No question about it. I would not be without runflats on a car with no spare.
Old Aug 11, 2005 | 08:05 PM
SLPRC5's Avatar
SLPRC5
If and when you do buy new tires of any kind make sure you get road hazard insurance on the tires. I didn't and my rear tires have two patches each and that has lessen the integrity of the tire for hi-speed. With insurance you can have the tires replaced fully or for pro-rate. Just my $.02
Old Aug 11, 2005 | 10:43 PM
1997C5's Avatar
1997C5
I had a leak in mine and it turned out to be a nail. Goodyear fixed it for around 45 bucks. I was also informed that if the tire runs completely out of air that it could damage the inner run flat material in the sidewall so I would make sure that you don’t let the tire run out of air completely.
Old Aug 11, 2005 | 11:00 PM
BickyDhadwal's Avatar
BickyDhadwal
Old Aug 12, 2005 | 06:31 AM
kwest2u's Avatar
kwest2u
Default Run flat
To Having a flat with run flats??
