Ok...help me decide
Old Aug 12, 2005 | 02:27 AM
vett_girl's Avatar
vett_girl
Default Ok...help me decide
I REALLYYYYYYYY Wanna lower the car.. But the BF isn't sure, he needs to know how difficult it's gonna be... Also, a big "THANKS" to my Blue buddie for sending "before & after" pics
Thanks everyone!
Does it need lowered??
Old Aug 12, 2005 | 02:41 AM
Midnight Storm's Avatar
Midnight Storm
v Down v
~MS
Old Aug 12, 2005 | 02:42 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Yes ... it NEEDS to be lowered! But then don't forget to get a 4 wheel alignment after it settles, so your tires don't wear funny.
Only takes about 20 minutes on stock bolts.
Old Aug 12, 2005 | 02:47 AM
gairno's Avatar
gairno
Yes you need to lower it. It looks like a four wheel drive.
Old Aug 12, 2005 | 02:49 AM
TruUndrtkr's Avatar
TruUndrtkr
Lower it..
Sox-Fan's Avatar
Sox-Fan
It's easy. I did it with a jack, two jackstands, and two wrenches in a couple of hours. Follow the guides posted here and you can't go wrong.
Old Aug 12, 2005 | 03:18 AM
BickyDhadwal's Avatar
BickyDhadwal
very easy to do...i don't know why i waited soo long
Old Aug 12, 2005 | 03:42 AM
JoshVette's Avatar
JoshVette
I'd say lower it too, just know what you're wanting first.
I know quite a few that do nothing but scrape the ground all the time and don't seem to enjoy it as much.
Old Aug 12, 2005 | 04:10 AM
Vegas Vette's Avatar
Vegas Vette
Drop it !! you wont regret it I just lowered my Z06 even more today....
Old Aug 12, 2005 | 04:48 AM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Drop it like a bad habit.
Peace of cake, the Dork can talk you through it.
Old Aug 12, 2005 | 06:27 AM
kwest2u's Avatar
kwest2u
Default Hey-drop it down a notch
Old Aug 12, 2005 | 06:30 AM
FiberglassFan's Avatar
FiberglassFan
Lower it. I had it done one sunny afternoon before my husband knew what was happening. If you have run-flat tires, you might need an alignment. If you have real tires, then your really probably OK because in the lowering, you will get a very small increase in negative camber. Thats good for cornering!!! , but runflats don't like it due to the extremely stiff sidewalls. Sadly, runflats need to fit square upright on the road so they can pretend to have traction.
Old Aug 12, 2005 | 07:06 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Yes it needs to be lowered. It's a simple job, simple enough you really could do it without the B/F
How?
More how?
Old Aug 12, 2005 | 07:10 AM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
I'm with DORK! J/K bro!!!! Dave... You know you're my boy!!!
VG, it really only takes about 15-20 mintues to lower it with (I believe) a 10mm....cant exactly remember. It takes longer to prep and jack up the car than it does to lower it. Compare for yourself....
First you have to insert the lifting pucks. If you dont have these GET 'EM.. $30.00-ish from Elite Engineering.com Then you have to jack up the car from the front and put it on jack stands. Then you have to take the two front tires off for easier access. Then you have to take pressure off the leaf springs in order to back the bolt out!
The actual lowering consists of unscrewing the bolt almost completely out and that's it. Takes about 3-4 minutes per bolt to do the actual lowering. Pretty huh!
Oh....one more thing... I can't keep up with all your avatar changes. I coulda swore I saw three different avatars in a matter of minutes
Old Aug 12, 2005 | 07:22 AM
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
If lowering will affect the drivability, then I would not lower it. It looks good to me from where I’m sitting.
Old Aug 12, 2005 | 07:57 AM
Glennm27's Avatar
Glennm27
Lowering WILL affect the drivability................... It will make it even better....
Lower that car..........
Old Aug 12, 2005 | 07:59 AM
Glennm27's Avatar
Glennm27
Well, that's the tool you need and how to do the FRONT.
You've given here half the story..........
Now, how about the rear.......................
To Ok...help me decide
Old Aug 12, 2005 | 08:42 AM
TOOGECKO's Avatar
TOOGECKO
I was very apprehensive about lowering mine, concerned about ground clearance and a harsher ride (I have a ZO6). I ended up having it moderately lowered (about 1-1/2 in.), mainly to close in the wheel gap. I can tell you that after six months I haven't had any more clearance problems than before (just need to watch the front on speed bumps and driveways). Additionally, it has a more planted feel when cornering and absolutely looks better than before. I say do it, conservative amount at first, then go from there.
Old Aug 12, 2005 | 08:46 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Good advice. I am still on the fence about this one. May do a little at a time.
Old Aug 12, 2005 | 08:48 AM
TLKSCHP's Avatar
TLKSCHP
I can't get the front of mine to lower. I have soaked them everything I have and they just won't budge. Good luck, but I would say lower it
