how do I fix this?
Old Aug 13, 2005 | 10:06 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default how do I fix this?
damn thing is starting to fall apart on me, noticed it last night.
gonna make it hard to sell.
Old Aug 13, 2005 | 10:10 AM
vettes4fun's Avatar
vettes4fun
Replace it or if you are going to sell it use two side tape
Old Aug 13, 2005 | 10:22 AM
sailohio's Avatar
sailohio
Just replace it. Forget the tape. Be responsible.
Old Aug 13, 2005 | 10:36 AM
ttaylor's Avatar
ttaylor
Use emblem adhesive. Both of mine broke and I could not get my hand to the back of the light to put the nuts on, so I just used 3M emblem adhesive. It has worked fine and been like that for almost a year.
Old Aug 13, 2005 | 11:41 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
How did it break to begin with??
Old Aug 13, 2005 | 12:06 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Fairly cheap to replace. I see them on eBay all the time. A bit ackward to replace if its the passenger side, you got to go up and under the car to get around the antenna. Not tough though.
Old Aug 13, 2005 | 12:41 PM
jrose7004's Avatar
jrose7004
Do it right!
Old Aug 13, 2005 | 12:50 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
The parts are cheap. You can partially remove the inner fender for easy access. I've ground 75% of the head down on a 1/4-20 1/2 lg. bolt and epoxied it to the light when I was in a hurry.
Old Aug 13, 2005 | 01:44 PM
ebubman's Avatar
ebubman
Originally Posted by jrose7004
Do it right!
there is no other way. bub
Old Aug 13, 2005 | 02:11 PM
b98's Avatar
b98
Old Aug 13, 2005 | 02:16 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
very small finishing nails
Old Aug 13, 2005 | 02:21 PM
carlmorrell's Avatar
carlmorrell
I had some similar breakage on the rear brake lamps on my daily driver. I removed the parts, and found the breaks were clean and with cyanoacrylate (aka crazy glue) and accelerator was able to reattached the broken standoffs. The repair has held for several years now.
Old Aug 13, 2005 | 02:46 PM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
Not a big deal getting them wet, I'd just get a towel and dry the water off. Wash around the side marker light too!
Old Aug 13, 2005 | 03:02 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
superglue sounds good to me.
Old Aug 13, 2005 | 05:03 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
my wife had a tube or TREMCO Clear Plastic & Emblem Adhesive seemed to do the job well enough.
Old Aug 13, 2005 | 05:33 PM
Dark-Knight's Avatar
Dark-Knight
, I really do agree.
To how do I fix this?
