Got Err message on CD player
Old Aug 13, 2005 | 02:35 PM
c5vette73's Avatar
c5vette73
Default Got Err message on CD player
Is there a quick fix to this, or is it a major repair or replacement job?
Old Aug 13, 2005 | 02:46 PM
Digmo's Avatar
Digmo
May have put a CD in upside down?
Old Aug 13, 2005 | 02:48 PM
c5vette73's Avatar
c5vette73
No, I thought that might be problem.
I read a thread that said disconnecting the battery for 5mins might work as this might be an electrical problem.
Old Aug 13, 2005 | 03:15 PM
HD_Rider's Avatar
HD_Rider
Your not using computer-burned CDs, are you? If so, try an "OEM" cd. Some CD-R media doesn't burn as 'cleanly' as name-brand media.
Old Aug 13, 2005 | 03:35 PM
BanditDude's Avatar
BanditDude
You may need to clean the lens.
Old Aug 13, 2005 | 04:07 PM
Alcee1's Avatar
Alcee1
Got the same thing awhile back, and also today after disconnecting the battery. Are you using a single indash CD player or a 12 disk changer like myself? All I did was oper the changer, took out the carrier put it back in and it started working again. For a single indash player I'm really not sure.
Old Aug 13, 2005 | 05:15 PM
c5vette73's Avatar
c5vette73
How do you go about cleaning the lens?
Old Aug 13, 2005 | 07:39 PM
Yoggi's Avatar
Yoggi
Some of the cds I burned wouldnt play.
Old Aug 13, 2005 | 07:45 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
...accessories do cause problems....
My disk Alpine was a problem from the beginning...
...took it out
anybody wanna by an alpine 6 disc changer...CD and MP3's
But not a desirable mod on Bose tuner...
Old Aug 15, 2005 | 08:51 PM
dooscoop32's Avatar
dooscoop32
Our 2004 convertible has the factory 12-disc changer in the rear. We drove to Myrtle Beach, SC on our vacation in July. All the way down and while at the beach, the changer worked perfectly. On our way back home, it wasn't working and we kept getting the "error" message. At the first gas stop, I decided to remove the items we had packed in the CD changer compartment. I then jiggled the wiring harness under the changer and tried it again. IT WORKED!! I thought maybe the harness had been moved by those things packed around it. Apparently so because it has worked perfectly ever since. It's worth a try.
CRVETTE
Old Aug 15, 2005 | 11:07 PM
Red73Vette's Avatar
Red73Vette
I did the same thing tonight - not more than an hour ago.
Jerry Minnesota
Old Aug 15, 2005 | 11:25 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
I get that Err from burned CD's ....what i found is i burn them at a slower speed and it has worked for me so far. I have the CD changer
Old Aug 15, 2005 | 11:31 PM
dyeggy's Avatar
dyeggy
St. Jude Donor '10-'11-'12, '14-'17,'21, '25
I have noticed this with my indash unit on my suburban. Burn it at a slower speed and try again.
Old Aug 15, 2005 | 11:34 PM
exukboy's Avatar
exukboy
I have a 12 stacker cd in the trunk of my 00 vert and it does the same thing. I took the unit out and took it apart. I cleaned everything even though it wasn't exactly dirty and put it all back together again. Same problem! ERR
I think my unit is defective. You can buy a brand new replacement unit but I listen to the radio now for what it's worth.
Old Aug 15, 2005 | 11:42 PM
thisMSGgood4me's Avatar
thisMSGgood4me
You insert a lens cleaning disc into the player and "play" it a few times. You should be able to buy the cleaning disc where you buy your audio cd's.
Old Aug 16, 2005 | 01:52 AM
Gmlover's Avatar
Gmlover
[QUOTE=HD_Rider]Your not using computer-burned CDs, are you? If so, try an "OEM" cd. Some CD-R media doesn't burn as 'cleanly' as name-brand media
I had the same problem. I have a bunch of the noname media. I had to slow the speed. Some of the cds work fine while others did'nt play too good. They work fine in my other vehicles. I'm going to try the name brand.
Old Aug 16, 2005 | 09:11 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
I was listenig to mine yesterday. It started to take awhile on random to select and play the discs and then stopped and I got the dreaded error code! I was going to ask the same question when i saw this thread.
To Got Err message on CD player
Old Aug 16, 2005 | 10:08 AM
mrtoner's Avatar
mrtoner
If your CDs are in correctly, and they are recorded correctly, you should be able to correct it quickly.
First, make sure your sound system is OFF
Slide the door to the carrier, and pop out the carrier. Check it, then re-insert it and close the door. You should hear the changer click through all the CDs. Wait until it is done, then turn on your system, and it should have cleared.
Old Aug 16, 2005 | 11:42 AM
CorvetteSteve's Avatar
CorvetteSteve
Will the In-Dash Single CD player work if the "Changer" is out of service(ie, missing the cartridge)?? Sorry if this is a stupid question. I found this little surprise when I brought the car home! Still love it though and I could really care less, it's the CAR I wanted.
I'm getting the "ERR" message also, but I've already been looking at aftermarket head units just in case I'm screwed on the factory unit!!
Old Aug 18, 2005 | 11:43 AM
mrtoner's Avatar
mrtoner
Always make sure the sliding door is FULLY closed.
I even put a strip of electrical tape with a folded tab to keep it secure.
It is too easy to bump the door and not realize it has popped out of position, causing the "ERR"
