Anyone know where "splice pack" sp208 is located
Old Aug 14, 2005 | 04:29 PM
SkankZilla's Avatar
SkankZilla
Default Anyone know where "splice pack" sp208 is located
I've searched the forrum and can't find the location of where it should be. I'm having some issues and believe they're related to the sp208 but i can't find a post on where it's located.
Old Nov 11, 2010 | 09:40 AM
dmills324's Avatar
dmills324
I think splice packs are a mistery to us all. I have been searching for infomation on them and can't find much. Anyone have the scoop?
Old Nov 11, 2010 | 09:59 AM
kpcets's Avatar
kpcets
Veteran: National Guard
In my 99 service manual for SP 208 it says the location: Instrument panel harness, RH side of Instrument panel, grounded to G104 (CKT 851)
Hope this helps.
Chicago1's Avatar
Chicago1
Billcurlee posted up pics where all the splice packs are located pic, turorials and all. Just do a search under his name shouldn't be hard to find. Just seen a thread about it a few weeks ago.
Old Nov 11, 2010 | 12:56 PM
dmills324's Avatar
dmills324
Thanks Guys
D
Old Nov 11, 2010 | 01:15 PM
dmarkshark's Avatar
dmarkshark
corrected per Chicago I, I was thinking of something else, and did not have the correct infor, sorry.
Old Nov 11, 2010 | 01:18 PM
dmills324's Avatar
dmills324
Old Nov 11, 2010 | 02:11 PM
Chicago1's Avatar
Chicago1
SP208 - Instrument Panel Harness on RH side of instrument panel
Old Nov 11, 2010 | 02:50 PM
dmills324's Avatar
dmills324
good stuff,,,,,
Old Nov 11, 2010 | 08:42 PM
Greg_E's Avatar
Greg_E
Hope this helps.
That's all I found, and it's the same for a 2000.
If you are having multiple symptoms, I would check G104 first. It seems more likely that an exposed ground would be the most likely place for a poor connection vs the splice pack in the protected interior of the car.
G104
Instrument panel harness, below the battery tray, on the RH frame rail, ground for SP208 (CKT 851)
Found more info.
See Bill's post #10 in this thread, for pictures. Keep in mind that the pictures are from a 1998, and the splice pack on that car was in the engine compartment. I don't know if the information in the manual is incorrect or the location of the spice pack changed on later models.
http://forums.corvetteforum.com/c5-t...m-tcs-etc.html
Old Nov 12, 2010 | 08:31 AM
dmills324's Avatar
dmills324
Thanks ,dmills324
To Anyone know where "splice pack" sp208 is located
