GM Bra Install Question
Old Aug 14, 2005 | 05:45 PM
Dave1998's Avatar
Dave1998
Default GM Bra Install Question
How do you attach the top wheelwell snap. What do you do with the tab ?
Dave
Old Aug 14, 2005 | 05:54 PM
DaBoz's Avatar
DaBoz
This will help...
https://www.corvetteforum.com/techti...D=32&TopicID=1
Old Aug 14, 2005 | 05:59 PM
Dave1998's Avatar
Dave1998
I got that sight, but where do you place the tab once you bend it ?
Old Aug 14, 2005 | 06:08 PM
DaBoz's Avatar
DaBoz
It hooks between the wheel well material and the body. When you snap it closed, it tightens up the bra. They are a PITA when new as they fit very tight.
Old Aug 14, 2005 | 06:10 PM
DaBoz's Avatar
DaBoz
Like this:
Old Aug 14, 2005 | 06:27 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
That is a good picture. I have to kind of feel for the right spot every time I attach mine. It is an acquired skill.
Old Aug 14, 2005 | 06:50 PM
Dave1998's Avatar
Dave1998
I get the idea that the tab is bent into a U shape. Is that correct ?
I am afraid of cracking the fender by forcing the tab between the wheelwell and fender. There appears to be no room there.
Old Aug 15, 2005 | 05:55 PM
Once you do it once, you'll think why didn't I think of that before. I had to think about how it attached when I first got mine.
Old Aug 15, 2005 | 08:01 PM
HummelS's Avatar
HummelS
Correct - it takes a little force, but you won't break anything.
Old Aug 15, 2005 | 08:02 PM
silverstreak01's Avatar
silverstreak01
on the GM bra, are the air vent openings covered by a screen or are they cut out and opened? also does GM have a fixed price or is it up to the dealer? I've been told they go for around $80.00. I'm looking for one to use on road trips only. Thanks for your input.
Old Aug 15, 2005 | 08:07 PM
HummelS's Avatar
HummelS
$80 is a pretty good price - dealer discretion as to whether they charge "retail" or not.
I assume by "air vents" you mean the fog light area or Z06 screens - it's covered by a clear plastic on the coupe/vert version, and open for the Z06 version of the bra. I have used the coupe version on our Z06 with no problems - might lose a couple of ponies, but it works fine, since the C5 'vette is a bottom breather when it comes to cooling air.
Old Aug 15, 2005 | 08:12 PM
Dave1998's Avatar
Dave1998
In the pic above, could someone please tell me whether or not the fender well tab is bent, or straight like when it came new.
I am convinced it is bent.
What I want to know is there 1 bend of 90 degrees, or 2 such that if forms a U and wraps around the outer fender.
Many folks have told me that the tab remains straight; but it dont look that way to me. I need a second set of eyes
Old Aug 15, 2005 | 08:15 PM
Wildcat99's Avatar
Wildcat99
It stays straight. I had the same problem when I first put mine on. Slip it the slot and push it in. Then snap it.
Old Aug 15, 2005 | 08:20 PM
DaBoz's Avatar
DaBoz
Mine is bent in a U...
gmpartsdirect.com has this about $82.00 delivered!
Old Aug 15, 2005 | 08:23 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
You have to bend the tab to get a hook shape that will hold behind the body shape. Then the snap will hold the bra tight.
Go ahead and snap it then pull the tab to see where you want the final hook to be then shape it to fit as the picture shows.
Good luck with the install.
Allzwell
Old Aug 15, 2005 | 08:38 PM
Z0SLIK's Avatar
Z0SLIK
Like this:
Old Aug 15, 2005 | 08:52 PM
Dave1998's Avatar
Dave1998
Its beginning to sound like the consensus is that indeed the tab is bent into a hook that goes around the outer fender. Well, I was beginning to think that but some insist it stays straight.
Are we all in agreement now ?
Old Aug 15, 2005 | 08:53 PM
DaBoz's Avatar
DaBoz
It must be bent. It cannot work straight.
Old Aug 15, 2005 | 09:29 PM
Dave1998's Avatar
Dave1998
Thank You ! I have not lost my mind and I have my pliers in hand and out to the garage I go !
To GM Bra Install Question
