HELP... My A/C Smells Weird
Old Aug 14, 2005 | 09:36 PM
gtoformula400's Avatar
gtoformula400
Default HELP... My A/C Smells Weird
Lately I've noticed that a terrible musty smell comes out of the vents for a few minutes when I first use the A/C... The car has always been garaged ('01 w/ 14.5K miles) so I'm not real sure whats going on. Is this normal or is there an easy solution to this. Thanks in advance everyone.
-Joe
Old Aug 14, 2005 | 09:42 PM
jrose7004's Avatar
jrose7004
Get all of the crap out of your udders(drains on the firewall!)
Old Aug 14, 2005 | 10:12 PM
rws.1's Avatar
rws.1
Autoparts stores sell an aerosol can for killing the bacteria and mold that can grow in your vents. It will lill it and freshen the smell
Old Aug 14, 2005 | 10:23 PM
H20Vette's Avatar
H20Vette
When you use your A/C and then turn the car off, condensation forms in the vents/ducts. This can cause mold/fungus to grow.
If you notice in your house, after the A/C runs, when it is ready to shut off, typically the fan will continue to run for a couple of minutes after the compressor stops. This returns the ducts to near ambient temperature and prevents the mold.
Whenever you use your A/C in your car, about 1-2 minutes before you shut down the car, turn off the compressor and put the fan on high. If you do this every time it won't smell as much.
If you have a lot of odor right now, though, you may need to spray some hydrogen peroxide down the vents to kill the funk that is growing in there.
Old Aug 14, 2005 | 10:35 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
-Joe
Get some stuff from the dealer called Fridgfresh...it should take care of your problem
Old Aug 14, 2005 | 11:54 PM
Der Flieger's Avatar
Der Flieger
Default AC smell
I recently got a strange smell form the air conditioner in one of my economy cars. I realized it smelled like MICE. I found a nest in one of the ducts. You might check your C-5 for the same thing.
Old Aug 21, 2005 | 05:16 PM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
Is there an intake to the blower ducting where one could spray a can of lysol or something before the vents?
To HELP... My A/C Smells Weird
