[Z06] honker and dynomaxx -- ???
Old Aug 15, 2005 | 08:23 AM
Joe C's Avatar
Joe C
Default honker and dynomaxx -- ???
i'm thinking about the calloway honker and the supermaxx system - long tubes, freeflow cats, and x-pipe, and keeping the stock z06 mufflers. got any ideas on what kind of power increases i might see? i'm thinking somewhere around +35 rwhp. am i high or low? anything else - what would be the biggest bang for the buck? i would like to do some bolt-on mods. comments...
TIA - JoeC - 2004 black/mod red z06
Old Aug 15, 2005 | 08:58 AM
Morzoff's Avatar
Morzoff
I went with the Supermaxx LT's and bigger injectors, If I remember right I went from 368RWHP to 383RWHP
Old Aug 15, 2005 | 09:58 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
LG Pro long tubes, went from 340 to 375 Plus I think they are lightest around...
Exhaust
Headers with H-pipe unless noted otherwise
68 lbs --- 97 stock double wall manifolds & h-pipe --- Source
72.5 lbs --- 02 cast iron manifolds with pup cats & h-pipe --- Source
46 lbs --- GHL 1-3/4" headers w/3" collectors & 3" Random Tech cats and x-pipe --- Source
52 or 61 lbs --- FLP LT's w/cats --- Source
49 lbs --- Kooks LT's w/high-flow cats --- Source
48.5 lbs --- LGM Pro LT's w/high-flow cats --- Source
45.4 lbs --- QTP LT's w/high-flow cats --- Source
50 lbs --- Stainless Works w/cats --- Source
63 lbs --- SuperMAXX LT's w/high-flow cats --- Source
see this awesome thread and book mark it for sure:
http://forums.corvetteforum.com/showthread.php?t=984927
I saw in Vette I think the new Honker put over 35 RWHP but that was with a FRC making over 400RWHP to start with. Looks like a PIA to install IMO. Go with a nice easy to install TRIC, LT a good tune and be 390rwhp +
Good luck!!!
Dave
Old Aug 15, 2005 | 05:36 PM
BradCZ06's Avatar
BradCZ06
I have the exact setup you are talking about on my 02Z. Didn't have a before dyno when stock so I don't know what I picked up from the mods. I am very happy with both. The sound of the exhaust and the extra power put a smile on my face every time I drive it.
Old Aug 19, 2005 | 09:13 AM
Sean2000C5's Avatar
Sean2000C5
I went with the blackwing, supermaxx and xpipe with stock exhaust and went from 349 to 382 rwhp after my dyno tune. The sounds is great and the quality of the pipes is top notch - HP Performance in Mundelien said it was one of the cleanest/best fitting setups they've seen for the vette.
Old Aug 19, 2005 | 09:55 AM
Jumper's Avatar
Jumper
I have the dynatechs and a Halltech stinger. 379 rwhp/367 rwtq in my 03 Z.
Old Aug 20, 2005 | 03:49 PM
LewP's Avatar
LewP
Default Effect of Intake Breather Doesn't Show UP on Dyno
I put on the LG LT's and the Callaway Honker. The dynojet said I gained about 57 rwHP. The Callaway or other intake that grabs RAM air is not likely to show on the usual dyno run. You can sure feel the RAM effect in the seat of your pants though.
Lew
To honker and dynomaxx -- ???
