Speedometer Not Working After Guage Bezel Install !!!
Old Aug 16, 2005 | 09:30 PM
spdnman's Avatar
spdnman
Default Speedometer Not Working After Guage Bezel Install !!!
I had to remove the guage cluster to fix the silver bezels that came loose. Does anyone know why my speedometer no longer works? Do I have to reset it? Did I royally screw up something major? Is it simply a loose coonection? All other guages work properly. Too late to rip the dash apart again.
Thanks for the help.
Old Aug 16, 2005 | 09:32 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
sad to say but your gonna have to rip the dash apart again. Sounds like a loose connection. You wont know for sure until you do it
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Since the gauges are liquid dampened ... maybe the way you laid the cluster caused something to go kaplooy. Hopefully, it's just a bubble or something ... Hope you get it fixed.
Check your connections first.
Old Aug 16, 2005 | 10:08 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Rawr Roo, George! Take your time, take it all apart again and see if you missed something.....sorry.
Old Aug 16, 2005 | 10:15 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the connector in the back of the cluster is prolly askewed
Old Aug 17, 2005 | 07:11 AM
spdnman's Avatar
spdnman
Tried reconnecting the plug in back of dash without fully removing cluster. Still the speedo does not work. Any ideas? Thanks.
Old Aug 17, 2005 | 07:17 AM
Digmo's Avatar
Digmo
with above. connection in back is hard to get to. Unplug and reconnect. Question? Does either speedometer in dash or heads up work, or are both dead?
Goos luck
Old Aug 17, 2005 | 07:27 AM
spdnman's Avatar
spdnman
Ok looks like I figured it out and will fix it tonight. Could not see it last night, but the speedo needle is stuck under the resting pin. Can I be the only one this happened to? Doubt it. Thanks for everyone's help, much appreciated!!
Old Aug 17, 2005 | 07:34 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
aawwww...I wanted to get to tell you that the needle is prolly pegged....
...very folks forget the connector...but the needle does get on the wrong side of the peg
Well while your in there again...add white face gauges
Hey ...have you done the CLB... good time for that too
To Speedometer Not Working After Guage Bezel Install !!!
