Which alignment specs after lowering?
Old Aug 17, 2005 | 09:09 AM
Mike04's Avatar
Mike04
Default Which alignment specs after lowering?
Just lowered my car, should I go with the coupe alignment specs or Z06 specs. The car is just street driven.
Old Aug 17, 2005 | 09:19 AM
jrose7004's Avatar
jrose7004
I went with ZO6 specs with .05 negative camber!
Old Aug 17, 2005 | 11:06 AM
viper8u2's Avatar
viper8u2
Old Aug 17, 2005 | 11:12 AM
User 81424's Avatar
User 81424
The Z06 specs found here
http://forums.corvetteforum.com/show...34&forum_id=49
will make the car more responsive, but some find this extra responsiveness (due to the increased neg camber) too "nervous" and it will increase you inner tire wear.
Old Aug 17, 2005 | 01:41 PM
Red-N-Ready's Avatar
Red-N-Ready
I just did mine...posted the same thread, some say go with the Z06 w/1 deg. neg camber, others say that this will prematurley wear the insides of the tires if you have runflats.....I opted to go back to the original factory specs and keep an eye out for wear. By the time it will be noticeable its probably gonna be to late. This is a very interesting question with equally confusing answers. Do a search on the subject and read up on it as much as you can, Iam still unsure on exactly which way is the best. One thing you must do is let the car "settle" before you go in for the alignment.....wait a couple weeks and put a couple hundred miles on the car. Good luck and let us know how it works out.
Old Aug 19, 2005 | 02:18 PM
Mike04's Avatar
Mike04
I am letting the car settle.... In the mean time I am looking for so more input as the alignment recommendation.
Old Aug 19, 2005 | 02:31 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
just do Z06
Old Aug 19, 2005 | 03:30 PM
MY1STPEWTER's Avatar
MY1STPEWTER
When I get mine done I'll be going back with stock. It handles good enough and I don't want any premature tire wear,
To Which alignment specs after lowering?
