2004 C5 Auto... Recently swapped 2.73 out and installed 3.42's also had a Predator tune. 1ST PROBLEM... At WOT the car cuts out and wont shift to next gear without backing off the accellerator. 2ND PROBLEM... Now on a steep freeway run uphill the check engine light came on. After exiting freeway the car shifts very hard. Park it and let it sit for several hours and the hard shifting stops, (check engine light still on). Tranny fluid temps were 198-205... Any ideas!!!??? Thanks
After reading numerous accounts of problems associated with the Predator system installation, I see that apparently the Predator program really screws up the C-5 computerized system. I really do not see any advantage if it does not work as advertised. If the system is restored to stock, the problems seem to just go away. Is there a message there? JMHO.
The first problem is , youre hitting your rev limiter.
The car is exceeding the designated rpm parameters, before changing gear.
Once you change from a 2.73, to a 3.42 rear end, all of this has to be adjusted properly.
The shift points are firmed up also...........perhaps too firm to your liking.
I have no clue about the check engine light.
Check the codes on your dic.
Did you install a Torque Converter. If yes then the computer is seeing to much slip and is sending a code that will cause the Check eng light and cause the hard shifting. You might want to PM Mike Mercury He can tell you anything you need to know about Gear swaping and the Predator programer Good Luck
also you can clear the codes to get you by for now
