Strange Message on Interface computer
Old Aug 17, 2005 | 12:49 PM
SRQC5's Avatar
SRQC5
Default Strange Message on Interface computer
Just one of those things...
About 1/8 of the time that I start my engine I recieve the message: "Pull Key...Wait 10 seconds"
What is this (anti-theft measure or bad code...) and how do i make it go away?
Old Aug 17, 2005 | 01:01 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
A quick search of the forum turned up the threads in the link below. You might start there to get caught up.
http://forums.corvetteforum.com/sear...t=on&forum_id=
Pull key wait 10 seconds could be a dirty pellet on your key, a bad ignition, or up to and including the pre-cursor to the dreaded column lock issue. You should also search on CLB and Column Lock on the C5.
This could be a symptom of a larger issue and you should get it looked at. Consider ordering a Column Lock Bypass for your car from Corvettes of Houston if it is a 6 speed. Do you know if any of the recalls have been performed? Is your car an Automatic? All questions that need to be answered.
Paul
Old Aug 17, 2005 | 01:03 PM
ModRed405's Avatar
ModRed405
Never heard of it
Old Aug 17, 2005 | 01:14 PM
johnjb7's Avatar
johnjb7
I am getting the same message and it is interesting that I am likewise seeing this message every "8" starts or so. I posted here this morning about this message that precedes a "Service Steering Column Lock" message - which if you get these two messages - the engine will actually SHUT DOWN. The manual says have it towed immediatley. The responses I have recieved for a resolution is getting a column lock bypass (CLB) installed. I am looking into it now.
Old Aug 17, 2005 | 01:58 PM
SRQC5's Avatar
SRQC5
It hasn't been a major issue so far...I am just afraid that some day I will not be able to start the car altogether
Old Aug 17, 2005 | 05:59 PM
Vector's Avatar
Vector
CLB now! - do not pass go do not collect two hundred dollars!
Old Aug 17, 2005 | 06:03 PM
DoomDRV's Avatar
DoomDRV
I have been following the CLB issue and the threads for over a year. I have recently installed the CLB - too many horror stories to count.
I have one nagging issue though. i have a 2001 6 speed and I did have all the recalls done (before I installed the CLB)- does that make a difference?
To Strange Message on Interface computer
