Help!
Old Aug 17, 2005 | 02:04 PM
bobdt173's Avatar
bobdt173
Cruise-In VII Veteran
Default Help!
I removed my tires for cleaning for the NCH and the front passanger side tire was wearing bad on the in side to where there was no tread. After I lowered the car I drove it for several hundred miles and it settled and had it aligned on 1-12-05 and had it aligned today. I took the old reciept in and they could not find the specs from the 1-12-05 alignment to see if they screwed up. I have only driven the car 4000 miles or less since then and never abused the car or hit any pot holes. The question is does GM have any warranty on 4 wheel alignments? Any questions, comments, and advice welcome. If there is any warranty info are there links?
Old Aug 17, 2005 | 03:38 PM
bobdt173's Avatar
bobdt173
ttt
Old Aug 17, 2005 | 03:40 PM
Humy's Avatar
Humy
I could not imagine any warranty covering your issue - but definately sounds like an alignment problem
good luck
Old Aug 17, 2005 | 03:49 PM
LB04CE's Avatar
LB04CE
Don't know of any Warrenty, unless you are still under GM
3 year or 36000 mile,
To Help!
