Rear View Mirror
Old Aug 17, 2005 | 06:10 PM
vette dan's Avatar
vette dan
Vette Dan
Default Rear View Mirror
How the heck does the power plug come off of the mirror. I can't find a tab to push or whatever.
Dont want to break it.
Going to hard wire radar detector.
TXS
Danny
Old Aug 17, 2005 | 06:39 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
There is a tab but I had the same problem. Took a pair of pliers to push down the tab and get a good grip on the plug, then you gently "rock the snot out of it" until it slowly comes out.
If you are using the hard-wired plug, you might be able to insert the mirror-end probe into the wiring harness without removing the plug.
It's probably worth a try.
Best of luck.
Old Aug 17, 2005 | 07:43 PM
TeamSpeed's Avatar
TeamSpeed
I found that using both hands, so that you can get 2 fingers pushing down on the tab, and then using both hands to wiggle the plug while pressing the tab.
If you are using my quickconnect, it might be sufficient for you to push the mirror all the way over to the passenger side so you can see the colors of the wires.
Old Aug 17, 2005 | 08:18 PM
steve8's Avatar
steve8
I had to use a pair of needle nose pliers to get mine off. I wasa worried about breakage also by hand. The pliers did the trick.
Old Aug 22, 2005 | 03:35 PM
honster's Avatar
honster
Cruising
Do any of you guys have an instruction write up on hard wiring to the mirror of the c5? Just got my Valentine One in today.
Old Aug 22, 2005 | 04:14 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
https://www.corvetteforum.com/techti...=165&TopicID=1
Old Aug 22, 2005 | 04:33 PM
honster's Avatar
honster
Cruising
thanks for the link, but the photos on this link, do not match the writting.
Old Aug 22, 2005 | 07:05 PM
Classic-Chevy-Guy
First you need a bracket:
http://www.greatlakestrophies.com/corvette.htm
Then I would use this wiring harness from this forum member, work great:
Can't find it, but will look later tonight
Old Aug 22, 2005 | 07:12 PM
Classic-Chevy-Guy
Found it:
http://mysite.verizon.net/ccm.gerber/quickconnect.htm
Old Aug 24, 2005 | 12:00 PM
honster's Avatar
honster
Cruising
would i need this $12.00 wire, if I purchased the remote display for hte V1?
Old Aug 24, 2005 | 12:44 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
anyone know what color wire to splice it into(mirror)?
Old Aug 24, 2005 | 01:09 PM
Classic-Chevy-Guy
Not sure. I would call Valentine and ask if power is needed at both places to have it work.
To Rear View Mirror
