California & Mods
Old Aug 19, 2005 | 02:14 AM
gogo4's Avatar
gogo4
Default California & Mods
Well... as I am located in the golden state of cali.
I would like to know what mods would pass the smog checks and such?I don't care about the visual but sniffer test is more importand.
Will cams / heads fail the sniffer?
I just smoged mine with a vararam and B&B Bullets and it passed , I am pretty sure that the inspector never had a vette in his smog place so he couldn't tell that i had an aftermarket "illegal" intake.
Anyhow I would like to do a CAM job on my car ... but just curios if i can pass or else id be in big trouble.
Old Aug 19, 2005 | 06:55 AM
Dark-Knight's Avatar
Dark-Knight
Check with the Bakersfeild group, they'll know....
Old Aug 19, 2005 | 11:26 AM
GOZ2FST's Avatar
GOZ2FST
I think as long as the cam is made out of organic tofu you will be fine. Be sure to be running the car on bio-diesel and if you have the bucks yank out the LS1 and sneak a Prius drive train in there.
This "Golden" state of ours is getting less golden all the time. Three of my best friends are leaving - to Washington, Texas, New Mexico...
In Texas I think it's a state law that if your car is American Made you get a tax deduction for all modifications that increase horsepower (you must attach dyno sheet to tax return). Machine guns are mandatory and ammo is free.
I'd get political here - but it's the wrong forum....
Old Aug 19, 2005 | 12:04 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
forget about running a straight exhaust, you'll need mufflers (smog test).
long tube headers with no cats are a no no too
Old Aug 19, 2005 | 12:56 PM
gairno's Avatar
gairno
Yes you can change the cam and heads and still pass smog. It will depend on what cam you want to go with. With the intake and mufflers you shouldn't have a problem. Headers are not legal in Calif even though I have them on my car. The best person to talk to about the cam is Andy at A&A Corvettes. I know for sure you could get by with a 224 or 228 cam and still pass smog. AFR 205 heads are the best on the market. Hope this helps you. Gary.
Old Aug 19, 2005 | 12:58 PM
gairno's Avatar
gairno
Thanks bro for the kind words. Always willing to help if I can. Gary.
Old Aug 19, 2005 | 02:29 PM
NetBob928's Avatar
NetBob928
Old Aug 19, 2005 | 02:41 PM
OBSESDD's Avatar
OBSESDD
Mods, mods and more mods... intake, headers, cam...
Have fun, look very cool, go fast and worry about it later!?!
Old Aug 20, 2005 | 12:11 AM
gogo4's Avatar
gogo4
Nice... I guess but. I highly doubt I can be in texas , NewMexico or any other place and make enough money at 21 yrs old to drive a vette .
So yeah I like california! biiiotchhhh...
I will def check out Andy at A&A I need all the info I can get. I passed my smog with an Vararam B2 the moron never smoged a vette, he couldn't tell if it was aftermarket or not lol. Thanx for your help.
Old Aug 20, 2005 | 12:13 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
If you add L/T Headers you will fail the visual! AFR Cylinder Heads are legal.
Old Aug 20, 2005 | 12:17 AM
GeorgeB's Avatar
GeorgeB
I passed no problem, see sig for mods. Note that the B&B shorty headers are the only truly C.A.R.B. headers right now.
Old Aug 20, 2005 | 12:28 AM
mercxrr2's Avatar
mercxrr2
I'm in the process of going through the same. I purchased Heads, Cam and z06 exhaust manifolds with cats. I never tried this, but their are a number of ls1 that pass with a TR224 cam. I plan to go with a Cheater cam. Stock idle or very close, able to lug the car down low, plus ~380 to 400 hp/ ~380 ft lbs of torque (where I can use it). There is a big write up in over at LS1 tech.
What also nice is it's optimized for stock exhaust car like mine.
BTW, I'm located san jose.
Mercxrr2
Old Aug 20, 2005 | 03:42 AM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default What works...
224 cam w/good tuning always works!
224/228 is better if it works-which it should (especially w/larger cubes) and good tuning-See Andy @ A&A if you are in Californica.
Basically the cam determines if it smogs.
As above, AFR 205's are great.
May the BOOST be with you!
Roy
Old Aug 20, 2005 | 12:09 PM
ROD BROWN's Avatar
ROD BROWN
Default Passing Smog
If you live in Cal.,give Andy a call(see below for tel.num.).I am sure he can answer all your questions.He built my engine and I passed smog without any problems.I have all the goodies on my car and as the other gentleman wrote,its all in the cam and tuning.Good luck!! Hope it works out for you.
To California & Mods
