Shift Knobs On 04/A4
Old Aug 19, 2005 | 12:50 PM
John Micheal Henry's Avatar
John Micheal Henry
Default Shift ***** On 04/A4
Has anyone used the automatic shift **** adapter?How do you remove the stock ****? Thanks
Old Aug 19, 2005 | 01:04 PM
Ghost Vette's Avatar
Ghost Vette
To remove the stock **** you must first pull the shifter all the way back to 1st. Then with a small thin screw driver at the front base of the **** you will find the clip. Carefully pry it out and the **** will pull of the shifter.
