Need help on fit
Old Aug 19, 2005 | 01:39 PM
MTurnbo's Avatar
MTurnbo
Default Need help on fit
Fred Beans has the red Z06 fuel rail covers for the 01-02. Can any of you tell me if they would fit a 2000? If so why would they be listed for the 01-02?
Old Aug 19, 2005 | 01:43 PM
Dyno Dan's Avatar
Dyno Dan
?????????? I thought ALL C5s fuel rail covers were interchangeable.
Old Aug 19, 2005 | 01:50 PM
QuikZilver's Avatar
QuikZilver
If you have 1 return line, then you can use the ones for a Z06. I know 97 & 98 had two lines. I don't remember which year it was changed from two lines to one line. I know someone else will chime in with that info. I have no idea why Fred Beans has them listed for only 01 & 02, as they will fit 01 - 04 Z06's and any C5 with the single line on the fuel rail.
Old Aug 19, 2005 | 01:51 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
97-00 valve covers had 2 steel braided hoses going through it, 01 up have only one
Old Aug 19, 2005 | 01:57 PM
MTurnbo's Avatar
MTurnbo
Nuts you made me get up and go out in the rain to the garage and look. My 2000 vert has a single braided line going into the left FRC and nothing on the right.
Old Aug 19, 2005 | 02:43 PM
QuikZilver's Avatar
QuikZilver
If you have only 1 braided line, then you are golden and the Z06 FRC's will fit.
Old Aug 19, 2005 | 07:30 PM
Mad_Maxxx's Avatar
Mad_Maxxx
oops, my mistake, 00-up! Sorry I got you wet!
Old Aug 19, 2005 | 08:32 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep the 2000 has 1 line
[IMG][/IMG]
Old Aug 19, 2005 | 08:40 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Try again.
97-98 were the only years with 2 fuel lines through the rail cover. 99-04 are all single line and interchangeable.
Old Aug 19, 2005 | 09:19 PM
LB04CE's Avatar
LB04CE
If menory serves me right.. you are correct....
Old Aug 20, 2005 | 06:50 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You should be good to go. Fred Bean's has them listed as 01-02 probably because they are Z06 covers which came out in '01. They should fit any Corvette with 1 fuel line up to the 04's.
Paul
Old Aug 20, 2005 | 07:04 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
They would look very nice on your car. My 97 has 2 lines on the drivers side.
To Need help on fit
