What's a good replacement shock?
Old Aug 19, 2005 | 03:32 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Default What's a good replacement shock?
2000 Coupe with Z51 suspension, time to replace the stock shocks.
What's a good fit with the Z51 suspension? Not looking for a marked improvement (handling is fine) just a good replacement shock. Also should I swap out the plastic sway bar end links with metal ones?
Old Aug 19, 2005 | 03:44 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Bilstein...has had a lot of good reviews...among FL gang...
Z51 suspension here too and I like the ride of StuzVette suspension however
but as long as you under your kwik lift...
...time for a swap to metal sway bar links...
could happen on StuzVette...
Old Aug 19, 2005 | 04:17 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Have a 2000 with the Z51 suspension myself. Recently replaced my shocks with the Bilstein Sport Shocks. I also replaced my plastic sway bar end links with the metals ones. I've heard that the plastic ones will break eventually.
I will admit that the ride is a bit stiffer though.
No complaints here.
Old Aug 19, 2005 | 04:34 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
yup!
Old Aug 19, 2005 | 07:57 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Bilstein Sports all round. Night and day difference between them and stock.
Old Aug 19, 2005 | 10:15 PM
Target Chaser
St. Jude Donor '05
Looks like it's unanimous. Bilstein Sports is exactly what I had in mind but wanted some input here first. Thanks for the info everyone!
Old Aug 19, 2005 | 11:25 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
2004 Z06 shocks are a GREAT replacement for a Z51 car.....
To What's a good replacement shock?
