Ls6...400 Rwhp?
Old Aug 20, 2005 | 04:32 PM
bigred6906's Avatar
bigred6906
Default Ls6...400 Rwhp?
Hey guys......i have an 03' Z06 with borla stinger cat backs and a halltech stinger intake....What other things should i add to hit 400 RWHP?
Old Aug 20, 2005 | 04:55 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Some AFR heads and a quality cam of your choice is a good start
Delivered 4/7/99
Order #BJVCGX
AAB,AG2,AQ9,B34,B84,CJ2,JL4,N37,T82,T96, UV6,U1S
Performance Mods
AFR 205 Head W/921 Comp Dual Springs, Crane Billet Lifters, Comp Moly-Chrome Pushrods, ARP Head & Rod Bolts
Comp Cam Custom Ground Int. & Exh. Lobe 3726 (232 @ 0.50 .595” Lift) @ 114 L.S.A. ground with “ICL “ 2 degrees advanced (114+2) (Vette Doctors Custom Tune)
ATI Underdrive Pulley, RollMaster Double Roller Chain, SVO 30# Injectors
FLP Headers, Halltech Tric with Cobra Bridge, Hotchkis Sway Bars & Metal End Links, B&M Ripper with, X-Pipe, Corsa Pro Series Indy Exhaust, Baer Cross/Drilled & Slotted Rotors, Hawk Pads, Russell SS Brake Lines, Ported MAF Ends, 172 Deg Stat, CAGS, Taylor Spiro-Pro Wires, APC Xenon Headlights & Fogs, Performance Hood Seal
Appearance Mods
Vette Essentials Custom Interior, Autobuffs Complete Engine Compartment Detail, Steering Wheel & Sill Decals, Euro Tail Lights/Amber, Lloyds Mats, Breathless Exhaust Plate, Folia Tec Painted Calipers, Y2K High Polished Wheels
Dynojet HP-425,TQ-390
Old Aug 20, 2005 | 09:39 PM
Dark-Knight's Avatar
Dark-Knight
Your probably doing 345 to 355 rwhp now, so you need to pick up another 50 in round numbers. LS1 edit, 160 t-stat, LT headers, cam and u/d pulley is another way to get you to 400 +.
Good luck!
To Ls6...400 Rwhp?
