Help - Check Engine Light went on
Old Aug 21, 2005 | 07:33 PM
NEBZO6's Avatar
NEBZO6
Default Help - Check Engine Light went on
While driving to a car show today I noticed the light. I immediately pulled into a parking lot and got out the manual. The light is on steady and it says "an emission control system malfunction has been detected on your vehicle".
I have an '02 ZO6 with 4,300 miles and a GM extended warranty. I shutter at the thought of taking my baby to a dealer but I'm not sure I have any options.
Any words of wisdom?
Thanks, in advance.
Old Aug 21, 2005 | 07:39 PM
Mark-44's Avatar
Mark-44
Fill the tank with 93 octane gasoline; easy on the burn-outs for a while... light will go out.
Old Aug 21, 2005 | 07:45 PM
Stevedore's Avatar
Stevedore
Active Streak: 90 Days
St. Jude Donor '03-'05-'06-'07-'08,'11 thru '17, '21
I've heard that can be caused by a loose gas filler cap. Worth a check.
Old Aug 21, 2005 | 08:16 PM
NEBZO6's Avatar
NEBZO6
Went right out to the garage and it appears to be tight. I'll try anything before I go to a dealer.
Old Aug 21, 2005 | 08:18 PM
NEBZO6's Avatar
NEBZO6
I'll give it a try. Thanks! (at 59 years old I 'm too cheap to be burning out $ 300 tires!)
Old Aug 21, 2005 | 08:30 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Go to this site:
www.97vette.com and follow the instructions near the bottom on how to decode your C5's computer codes. Post the codes here and it should lead to a diagnosis. Codes with an H after them are history codes and have cleared, codes with a C are current. Post the codes (likely in the PCM section 10) once there, press and hold the reset and the light will go out. Let us know what you find.
Paul
Old Aug 21, 2005 | 08:39 PM
fop91's Avatar
fop91
Do you have a Cags Skip shift eliminator installed ? I installed one on mine and it worked for 3 months ok then my check engine light came on and stayed on. Took it in thinking it was covered under warranty. Turns out the skip shift eliminator I put on went bad and threw the check engine light on. they charged me $90 for analysis and said your part you put on caused the light to come on. When they took it off the check engine light went out. I purchased another one and have had no problems since. If you put one on you might want to check and see if it went Bad. Hope that helps you.
Old Aug 21, 2005 | 08:46 PM
NEBZO6's Avatar
NEBZO6
I don't have the Cags Skip installed but thanks for the suggestion.
Old Aug 21, 2005 | 08:54 PM
NEBZO6's Avatar
NEBZO6
Originally Posted by talon90
Go to this site:
Paul
Thanks for the suggestion. I went to the site and printed the info. I probably won't get to it tonight but will tomorrow after I get home from the office.
Thanks, again!
Old Aug 21, 2005 | 09:43 PM
vettemike's Avatar
vettemike
Happened to me on a cross country trip...turned out to be a different brand and octane of fuel (91 down from 93)....went off after I burned about half a tank.
To Help - Check Engine Light went on
