Headlight Motor question
Old Aug 22, 2005 | 01:35 AM
Nates99ss's Avatar
Nates99ss
Default Headlight Motor question
Tonight I go to see a movie with the girl, come out, start the car, turn on the lights and only the driver side headlight pops up...anyone ever had one light stick and the other come up? Im guessing my motor needs to be replaced, but not sure.
Old Aug 22, 2005 | 04:25 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
gear is worn out....I can send you detailed instructions with pics if you want to DIY....
Old Aug 22, 2005 | 06:13 AM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
Get the brass gears from http://www.rodneydickman.com/retail.html
Not a bad fix, good luck!
Andy
Old Aug 22, 2005 | 06:52 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As others have indicated it is probably the gear in the motor. The brass gears are the best option. In the mean time, others have had luck opening it up and rotating the gear 180 degrees since it operates on half the diameter to work the lights. You can also find replacement gears and motors from Mid America as well as other catalogue sites.
http://www.madvet.com/shop?frame=2.5749
Paul
Old Aug 24, 2005 | 02:56 PM
Nates99ss's Avatar
Nates99ss
pewter99 please send me a PM with the DIY. Im currently out of town, and I have already been hassled for the headlight by the cops, so Id like to try and get it up before I drive back
To Headlight Motor question
