[Z06] Need trunk lid assist spring info.
Old Aug 22, 2005 | 11:05 AM
HP_Addict's Avatar
HP_Addict
Default Need trunk lid assist spring info.
My trunk is not popping fully when opening it. I remember reading a while back that an assist spring can be added to provide additional opening. I did a search with no luck. Does anyone know the size, type spring that needs to be put onto the hydraulic shocks?
Chris
Old Aug 22, 2005 | 11:09 AM
DPG's Avatar
DPG
St. Jude Donor '06
I need help for mine too. Do I just get new shocks or bigger ones?
Dave
Old Aug 22, 2005 | 05:19 PM
IsItFast's Avatar
IsItFast
First off, take some WD40 (or similar) and spray the hinges and the latch. That fixed mine. Or if you are getting out, pop the lid BEFORE you shut the door; the air pressure inside will pop it open.
Old Aug 22, 2005 | 05:57 PM
AFVETTE's Avatar
AFVETTE
My buddy invented this, it helps to a point as does all the other home made remedies folks will offer.
He bought a big fat spring from Home Depot. You'll notice all the over spray from the WD-40. Nothing seemed to help me. The spring mod is about a 30% solution.
Good luck
Tom
Old Aug 22, 2005 | 09:40 PM
ZaydeZ06's Avatar
ZaydeZ06
Old Aug 23, 2005 | 07:59 AM
Fredsvette's Avatar
Fredsvette
Cruising
Mine's an 03 and lid stopped popping up. I used silicone spray on the latch and latch hook and it cured it. It now pops about 1.5" when I release it with the fob from outside the car.
Old Aug 24, 2005 | 02:03 AM
TheDVS1's Avatar
TheDVS1
I would use a helper spring as a LAST-RESORT. My '04 Z's lid started sticking a few months after I got the car. Some Teflon spray and WD-40 on the latch assembly would cure it only temporarily. Eventually I tried some good old-fashioned white lithium grease I had in a spray can. It's been fine now for over a year...
Old Aug 24, 2005 | 02:47 AM
SLO VETTE's Avatar
SLO VETTE
i too did the wd-40 mod to the latch mechanism... now it works PERFECT!
also sprayed some on the center console hinges on the interior (it was sticking). same result. now it's smoooooth....
try that solution first on the trunk before any real physical modifications.
Old Aug 25, 2005 | 12:57 AM
PowerMad's Avatar
PowerMad
The trunk on my '01 has never "popped" up more than 1/4 to 1/2 inch. It is just enough to get my fingers under it to raise it. There are two stops at the back corners of the trunk frame. Adjusting the height of those stops adjusts the pressure applied to "pop" the deck lid open. Raising the stops too high is bad because the rear edge of the trunk lid will be raised high enough to look funny and, can allow air and water leaks through the seal at the rear edge of the trunk.
Hope that helps,
dave
Old Aug 25, 2005 | 09:52 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Worked for me too... I tried the others below (no spring) but WD40 cured it.
Dave
Old Aug 25, 2005 | 09:59 PM
Sean2000C5's Avatar
Sean2000C5
I went to the dealer and they replaced the latch under warranty.
To Need trunk lid assist spring info.
