Cruise control...just figured this out...
Heh, heh, and everytime you 'tap' the little slide switch, it will increase the speed by one mph.
Amazing, huh?
Control
There are two ways to go to a higher speed:
• Use the accelerator pedal to get to the higher
speed. The speed will not begin to increase
until sufficient pedal travel is achieved. Press the
SET button at the end of the lever, then release the
button and the accelerator pedal. You will now
cruise at the higher speed.
• Move the cruise switch to R/A. Hold it there until
you get up to the speed you want, then release
the switch. (To increase your speed in very small
amounts, move the switch to R/A briefly, then
release it. Each time you do this, the vehicle will go
about 1 mph (1.6 km/h) faster.)
The Driver Information Center (DIC) will display the
cruise set speed.
Reducing Speed While Using Cruise
Control
There are two ways to reduce speed while using cruise
control:
• Press in the SET button at the end of the lever
until you reach the lower speed you want, then
release it.
• To slow down in very small amounts, press the
SET button briefly. Each time you do this,
you will go about 1 mph (1.6 km/h) slower.
cruise set speed.
Tom
We don't need no stinkin manual?
And if we did have one, who would we get to read it for us?
