new problem with head lights - help
Old Aug 25, 2005 | 10:15 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Default new problem with head lights - help
My head lights work fine - the go up and down when switched on and off - BUT now the motor on the left one continues to run for several seconds AFTER I switch them off and the lights retract. Is there a cut off switch on the assembly that is bad?
Thanks,
rr
Old Aug 25, 2005 | 10:27 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Thanks,
rr
Hello RR,
Your nylon gears have stripped and are probably missing a couple of teeth. You can get brass replacements which will fix the problem here: http://www.rodneydickman.com/retail.html
It is a very common problem and the replacement gear should last a lifetime instead of only a few years of normal use.
I am local so if you would like more info to see in person if you wanted to tackle this fix yourself, feel free to send me a PM.
1997C5's Avatar
1997C5
I had the same problem 2 weeks ago. It was a cracked gear. I went to http://www.rodneydickman.com/retail.html and ordered the brass gears and replaced them last week. Best $80.00 I spent on my car! Even comes with detailed How-To instructions. Much cheaper than buying a new motor. Hope this helps. -Ed
Old Aug 25, 2005 | 10:38 AM
Road Runner
Thanks guys. I'm ordering the gears today.
rr
Old Aug 25, 2005 | 11:11 AM
DBGMOO's Avatar
DBGMOO
Originally Posted by jdmvette
Hello RR,
I too have the same problem. Thanks for the link for a fix. On a scale of 1 to 10 how hard is it to fix? Thanks again jdmvette. Jerry
Old Aug 25, 2005 | 02:48 PM
1997C5's Avatar
1997C5
I found it easy to replace overall because step by step instructions are included with the gears. However, I did find it alittle tought to get to some of the nuts to remove the headlight assembly but not impossible. Not a difficult process just put side about 1 hour or so and read the instructions and you should be good.
To new problem with head lights - help
