Help!!! Tire sensor or BCM or ???
Old Aug 25, 2005 | 07:00 PM
cadawg's Avatar
cadawg
Default Help!!! Tire sensor or BCM or ???
I get the message "RIGHT REAR TIRE FLAT" when I first start up the car after its been sitting for a while. The message will go away after about a half mile. I've checked the PSI and it is okay. This message only comes up after the car has been sitting for a while and has progressed from only every once in a while to very often. I retrained the tire sensors but still the same issue. I called dealer and spoke with a service adviser and he said could be a sensor in which case would run me 300-400 dollars, but more likely to be BCM which would run me a few thousand dollars, and I would need to leave the car with them to analyze. Any suggestions before I take the car to the dealer?
Old Aug 25, 2005 | 07:11 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I would bet it's the sensor. I believe there is a relay in the fuse box near your battery. It wouldn't hurt to remove it and see what codes (if any) you throw; this might actually just disable the TP monitor circuit, just a guess. I counted 7 relays with the same part number in there on my 97...you could switch them around and see what happens. Switch it with the one for the parking lights...wouldn't hurt anything. Then see if you get different codes...poorman's way of diagnosing
Old Aug 25, 2005 | 07:24 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Pretty sure its the sensor as well. I have had a similar issue with my car.. and it was the sensor...
steve
Old Aug 25, 2005 | 09:12 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05
300-400 for one sensor?! Run away! Buy a replacement sensor from a forum sponsoring shop like http://www.corvettegarage.com/produc...-Corvette.html
Take it to a tire shop, and they will have to break the bead on the tire, at least halfway dismount the tire, replace the sensor, remount your tire. You should be good for around $100, and you already know how to retrain your sensors.
To Help!!! Tire sensor or BCM or ???
